bad O2 censor, Code 32
Old Jan 3, 2001 | 08:44 AM
Pino91Formula's Avatar
Would a bad O2 sensor cuase the EGR system to malfunction, or cause a code 32 , Just wondering , my car is back at the shop after code 32 reappeared. Im just trying to figure what the heck it's doing
Pino
91'Formula
LB9 305 TPI 5-speed
WS6 17" wheels
Eibach Pro-Kit Springs
Hotchkiss STB
SLP exhuast
SLP Cold Air Induction
CatCo Hi Flo Cats
http://www.geocities.com/MotorCity/Garage/5654/mur91.jpg
and the for ever returning CODE 32
Old Jan 3, 2001 | 05:10 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
No it wouln't. The O2 sensor and the EGR are two completly different sytems and do not share any funcion, diagnostics, etc... If that shop said that the O2 sensor caused a 32, its time for a new shop. Like they always tell us at work, if you can't "change" the employee, than you need to change the employee. Catch my drift?
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Jan 3, 2001 | 05:38 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Some ecm calibrations look for a O2 change when the EGR applies. Rare not to set a 13/44/45 more often thou
Old Jan 3, 2001 | 06:48 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Very unusual considering the nature of the O2 sensor, what it does, and how it responds.
South East Thirdgen
Savannah, GA
'87 Trans Am
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
Old Jan 4, 2001 | 07:58 AM
Im just trying to figure out whats going on thast all, the system is all new , egr vacume solinoid, and vacume hoses, you aply vacume the egr valve opens and holds vacume. what els could it be?
Old Mar 8, 2001 | 08:31 AM
WEll just to let everyone know ,, who might be going through the same thing i did. I finally figured out what was wrong , after changing egr valves and os sensors and vacume lines and vacume soilinoid . after i had the car inspected for imissions and it passed perfectly ,, i was crusing it that night and blink it came on again , code 32 , well after ready my service manual from the dealer. it said that the ecm checks the map sensor for a drop in preasure to see if the system is working , the egr system that is. well i spent the 30 bucks and replaced the map sensor and its worked fine ever since .
Old Mar 8, 2001 | 09:23 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Moral of the story...don't go by SES codes by themselves. I have found a number of times that when another sensor (in this case your MAP) gets "weak" that other components will attempt to "compensate" and they end up triggering the SES code.
You need to have a scan tool running at the time the code is set to properly see what is going on and to isolate the problem.
FYI, I found that if my eprom wasn't erased quite long enough (yet good enough to think it was blank and acceptable for programming), that I would trigger a code 32. Increasing the erase time by 1 minute always cured this problem.
Go figure.
Old Mar 12, 2001 | 07:58 AM
Well I spoke too soon, the damn thing came back on this weekend after a whole night of driving to various places and it was all highway until i went to drop off my buddy and i was crusing home ,then it came back on .... back to the drawing board. anyone have any ideas on what els to check?
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
db057
Jan 10, 2020 08:55 PM
racereese
Oct 3, 2015 03:46 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
