Porting the Plenum???
Old Mar 12, 2001 | 10:29 AM
KamaroZ350's Avatar
Car: 2008 Jeep Wrangler Unlimited
Few Questions...
What Exactly is porting the plenum doing? Like Gutting the TPI unit right???? Making the inside of it wider and all??? To of course alow more air into the engine...
DO you have to take your plenum to a machine shop to have it ported??? I have no idea how to do this or what tools are needed so i took it to two machine shops i know of, NAPA and Car-Quest, and neither one said they do that kinda work .... I dont know of any other machine shops around that might do this and its something i want done.
And is it a noticable difference when you port it??? If anyone has some be4 and after pictures, id love to see em...
Oh, and what do people mean when they say "Polish" it?
1991 Z28 Camaro L98
5.7L T.P.I
Blk ext/grey lthr int
http://www.iroc-z.org/albums/KamaroZ91/
http://www.fbody.com/members/KamaroZ350/
Old Mar 12, 2001 | 11:12 AM
chris1roc's Avatar
I just had a post about this check the archives. I'll e-mail you something that vader gave me.
88 iroc
LB9 305 tpi
k&n, flowmaster, ADS chip
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
Old Mar 12, 2001 | 11:23 AM
chris1roc's Avatar
this site also has a link I think that was at the bottom of the page that tells you how to polish the plenum.
http://www.tribal-treasures.com/cars...-port/port.htm
88 iroc
LB9 305 tpi
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
Old Mar 12, 2001 | 05:27 PM
Jas89TTA's Avatar
Check this guy out he's porting my plenum right now I've heard good things about his port work he was recommed to me from someone that had some items ported by him and they were pleased. His site is http://www.isthq.com/~dan/efi.html
Old Mar 12, 2001 | 09:57 PM
rondubbs's Avatar
i wouldnt pay anyone to port your plenum, its too easy of a job,,, follow the article and you'll be fine,, if you dont have a dremmel just use a drill with a rasp bit on the end.. its an easy project.
Old Mar 12, 2001 | 10:16 PM
KamaroZ350's Avatar
If you port only the plenum, wouldnt it caus to much air traffic and "slow" the car it down if you dont upgrade the runners to??? How about the TB?
Old Mar 13, 2001 | 07:08 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Porting the plenum, even without doing the runners, will help. Especially the EGR walls right behind the throttle body. I've got some good pictures, but you won't have to go as far as I did, because you don't have the runners.
http://members.home.net/rcrabine/porting.html
Bob '89 Ram Air Formula 350
Last(lost)Member of the Elusive Great Lakes Crew
My car's homepage
Old Mar 13, 2001 | 10:52 AM
rondubbs's Avatar
pretty much all you are doing when you port the plenum is take out the egr walls that slow down the air flow,, it dosent cause too much air flow , it just smooths out airflow.
Reid Fleming
Oct 10, 2015 09:56 PM
toronto formula
19
Oct 6, 2015 12:27 PM
bplessy
Sep 30, 2015 12:14 PM
