MSD IGNITION, need some help
Old Mar 11, 2001 | 12:52 PM
Kyle F's Avatar
I have the MSD 6A installed in my 86 Trans AM 355 TPI. I nee dto know what part I need to prevent the tach from Jumping around under hard acceleration.
Thanks, Kyle F
Old Mar 11, 2001 | 02:51 PM
Guest
Guest
Posts: n/a
The MSD tach adapter will prevent that. Its ugly FYI.
Check the archives, there is something about the jumping tach, and Im not sure if someone had traced down what the tach filter was on the cars that dont appear to have one. I never found anything besides wire, and I traced the line all the way from the dist. to the tach itself.
Old Mar 11, 2001 | 03:08 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Its not ugly. It looks like a red square with MSD on the top.
Look next to passenger side strut. The little red box Thats it
[This message has been edited by Mkos1980 (edited March 11, 2001).]
Old Mar 11, 2001 | 03:46 PM
Guest
Guest
Posts: n/a
Then they must have changed it. Mine is an ugly *** POS, looks like something from a yard sale.
Old Mar 11, 2001 | 08:35 PM
Desert86Roc's Avatar
I would double check your installation...My 86 Tac works just fine without any filter or special hookups.
Mike Metzler (Desert86Roc)
Mike@SpeedworldMotorplex.com
[*] Webmaster: SpeedWorldMotorplex.com[*] Click Here For My Racing Page[*]86 IROC 305 TPI (406 build in progress)
ET's @ 1250 ft[*] 14.28 @ 95.461 mph (uncorrected, NOS, no headers)[*] 15.365 @ 86.785 mph (uncorrected, Headers, no NOS)
Old Mar 11, 2001 | 09:00 PM
Kyle F's Avatar
Mine works fine to except for WOT it likes to jump around in the upper RPMs
Old Mar 13, 2001 | 08:19 AM
Try routing the tach wire away from spark plug wires.... Are your plug wires new/old/unknown? I had a set that was causing a lot of ignition "noise" and put a good set in. Took care of the problem.
Old Mar 13, 2001 | 09:22 AM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
I have the old style ugly tach adapter I'll sell for 15 bucks shipped to your door...(as long as you are US).
My 6AL went in without any adapters...I had the tach jumping problem, but it ended up being my ignition module was bad.
Good Luck
GregF
87 IROC
Old Mar 13, 2001 | 05:49 PM
Kyle F's Avatar
Well my car runs strong and It has MSD wires so i thin everything is fine in that department. Im just trying to get it to a Solid well performing state so i can sell it knowing that the next owner will be happy
FOR SALE!!!!!!!!!!!!!!!
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,MSD 6A, Hypertech Power Coil, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, MSD Wires, removal of A/C hardware and added a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace added. Soon to have Intrax lowering springs.
http://geocities.com/SunsetStrip/Garage/9548/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/4 ton 350, one of those NASCAR F150's
The Third Gen Will Never be Forgotten
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
meeklay812
Oct 1, 2015 03:46 PM
RedLeader289
Sep 23, 2015 06:50 AM
