heads?
Old Mar 20, 2001 | 07:26 AM
custman87T/A's Avatar
heads?
Will 1986 58cc aluminum vette heads work on my 87 5.0 TPI motor. If so what changes would be needed to complete since one of my heads are shot I have to look into other options. Does anyone know how much the S/R torquer 305 heads are unassembled since I might use this as another option. Thanks
Old Mar 20, 2001 | 08:10 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Assembled heads are usually a better deal than doing it yourself. Consider you have to grind all the valves, buy the springs, assemble, etc.
I believe to run the vette heads with the 1.94 valves, you may have a valve to cylinder wall interferance. I don't recall exactly, but I thought the 305 needed the cylinder wall notched. Maybe that was with a larger valve.
Mark.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
