TPI Vacuum Line Help
Old Oct 5, 2007 | 08:12 AM
ChampionN84's Avatar
Car: 91 Camaro Z28
I have a 91 tbi that i converted over to 87 TPI. I checked the diagrams on thunderchevy or whatever site it is but they are not exactly the same. I wanted to know if this looks like the correct configurations. I have included a drawn pic (Sorry) and also some pics of the connection to give everyone a better idea what i am talking about. Please help and thanks in advanced.
Old Oct 5, 2007 | 08:20 AM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Re: TPI Vacuum Line Help
from the drawings it looks like you have it correct, you could get away without the connection to the purge canister. Do your heater controls work?
Old Oct 5, 2007 | 08:30 AM
Car: 91 Camaro Z28
No but they are great sources for vacuum! When i turn on the ac i would assume that the one running to the coolant valve would suck more then it does to divert the coolant but it stays the same?
Old Oct 5, 2007 | 08:31 AM
Car: 91 Camaro Z28
What does that purge line do anyway?
Old Oct 5, 2007 | 12:26 PM
battman's Avatar
It circulates the gas fumes from the tank into the engine.
Old Oct 5, 2007 | 12:34 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Ive been working on the same thing. TBI to TPI.
I think you have it mostly correct. I have my vent, pvc, booster all kinda connected up backwards(different spots)... along with my purge.
Old Oct 5, 2007 | 12:46 PM
battman's Avatar
I did the swap myself about 2 weeks ago on my wifes 92RS, I used the tbi to tpi repin thread. The car runs better and has a nice power increase as well
Old Oct 5, 2007 | 12:52 PM
Car: 91 Camaro Z28
So that top line on the purge canister sucks gas fumes into the engine? So me hooking it up to the TB is good.
Also maybe you can tell me the answer to my other posts:
https://www.thirdgen.org/forums/cool...blems-fan.html
https://www.thirdgen.org/forums/elec...fan-issue.html
https://www.thirdgen.org/forums/tech...help-pics.html
Old Oct 5, 2007 | 01:00 PM
Dale's Avatar
Engine: 350 S-TPI
I posted on your top one there, others I dont know.
hopefully some others can chime in on mine and see if it should work the way I have it. I'm waiting on my ecm.
Brake booster to lower intake manifold, left side.
Valve cover vent tube is now a moroso open breather
PVC is to the right side of the TB.
EGR is now digital
AC doors, purge, FPSU, MAP, Cruise/vac bulb all have there own ports.
Extra hole on TB is capped off
coolent bypass hose has been melted in half. bypass valve removed.
Sound like it should work?
Old Oct 5, 2007 | 01:02 PM
Car: 91 Camaro Z28
sounds like it but do you have a drawning or pics they help out so much!
Old Oct 5, 2007 | 01:17 PM
battman's Avatar
Dale, sounds like it will work, you want me to send you some pics of how I ran mine?
Old Oct 5, 2007 | 01:24 PM
Car: 91 Camaro Z28
i think you should post them for everyone i would like to see your setup as well? Please
Old Oct 5, 2007 | 02:36 PM
battman's Avatar
I will post them when i get home today
Old Oct 5, 2007 | 03:05 PM
Dale's Avatar
Engine: 350 S-TPI
I dont have any drawings of mine, and above typing was from memory of over a week agos work.
I can sketch something out later tonight and verify where everything goes.
theshackle
Mar 5, 2017 06:37 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
apie2546
Aug 10, 2015 05:43 PM
