305 TPI EGR questions
Old Mar 30, 2001 | 06:13 PM
nebulous's Avatar
Car: 91-Trans Am-WS6
Engine: L05 350 - ATI 9psi
Transmission: Pro-Built:Street/Strip
The previous owner of my 305TPI switched the EGR canister to the driver side to fit the supercharger in. Only one of the three tubes that are connected to it go anywhere. Could someone please tell me where each tube is intended to go from the evaporative canister? Also wtf is the sphere thing?
Old Mar 30, 2001 | 06:17 PM
cobrakiller1989's Avatar
see if this helps. i asked a similar question before.
https://www.thirdgen.org/messgboard/...ML/001874.html
Old Mar 30, 2001 | 09:52 PM
Yarnboy's Avatar
Yea really!! What the foodle is that sphere thing?! I've always wondered..Does the Charcol canister affect performance? Or is it just emissions...Thanks
  • Red '88 IROC 5 Speed 305 TPI w/3.08
  • Dual Friction Stage III Centerforce Clutch
  • Accel 300+ Racing Ignition
  • Accel 300+ Pro Sleeve Plug Wires
  • AC Delco Rapid Fire Plugs
  • Flowmaster Force II 3 Chamber Cat Back Exhaust
  • Hypertech Chip
  • Hypertech Airfoil
  • Gutted Air Box
  • Best Maryland(40 degrees) E/T 14.686, 60' 2.205, 1/8th mile 9.461, 1/4 mile MPH 93.91
  • Best Florida(80 degrees) E/T 14.88, 60'2.163, 1/8th mile 9.540, 1/4 mile MPH 92.74
  • Best 60' 2.163(Florida)
  • TPiS AFPR set to 42psi using Accel Fuel Pressure Gauge (Installed after Maryland run)
  • Aluminum Driveshaft (Installed after Maryland run)
Old Mar 30, 2001 | 10:49 PM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
the sphere thing? possibly the vaccuum resevoir.
Old Mar 30, 2001 | 11:45 PM
rezinn's Avatar
Charcoal canister is just for emissions. Fuel vapor is sucked into the intake manifold via a purge valve on the canister. If it gets clogged it creates vacuum in your fuel lines which causes your fuel pump to have to work harder to do the same thing(or less)...
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
