Lifter question with xfi-268
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
To those using this cam, did you have to upgrade to aftermarket roller lifters as well because of the large lift? I read somewhere stock roller lifters will fall into the lifter valley too far and destroy the new cam in seconds. I am a cam newbie and want to budget everything for the new motor(E-tec 200 headed LTR TPI with xfi-268 cam)
thanks gurus
thanks gurus
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Re: Lifter question with xfi-268
I am running stock replacement lifters as well, no problems here either
Sweet, I was hoping I didn't have to buy new ones.
Thanks guys
Thanks guys
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
unless yours are worn out from high mileage...those lobes are pretty aggressive so you'll want fresh lifters...as long as yours look good they should be fine
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
E-Tec 200 heads and XFI 268 cam running here, no problems with stock-style lifters.
Car: 88 firebird
Engine: 350CI
Transmission: 5speed
Axle/Gears: 373s
for that combo do u need to have mass air style or will it work fine with out.. what 1/4 mile numbers u running?
Mickeyruder
Sep 2, 2015 02:45 PM
