GTA roll call.
Old Mar 15, 2001 | 06:29 PM
black5.7GTA's Avatar
GTA roll call.
Just curious as to how many are here?
1990 Trans Am GTA,Black/Black Leather,350,auto 3.23,Dual Cats,
SLP Package,SLP Torque Converter/Shift Kit,Fastchip,GSC's,
G-tech 0-60 5.1 1/4mile 13.6@104
Previous Thirdgen
1986 Camaro IROC-Z
[This message has been edited by black5.7GTA (edited March 15, 2001).]
Old Mar 15, 2001 | 06:32 PM
SpankuGta's Avatar
One here.
88 GTA 73k miles
Flowmaster catback,Random tech high flow cat,Ported plentum,Hypertech afpr and air foil,cold air induction,Msd blaster ss coil,cap and rotor and Super Conductor wires.Best ET 1/8th 9.21 at 77 mph.All mods were done within two weeks after purchase.
Old Mar 15, 2001 | 06:41 PM
5.7 or 5.0?
member www.transamgta.com
Previous Thirdgen
1986 Camaro IROC-Z
Old Mar 15, 2001 | 06:47 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
Present.
Black 88 GTA L98
261 RWHP, 345 RWTQ
ZZ4 bottom end, Edelbrock 6085 heads, LT4 HOT cam, GMPP 1.6 RR's, ported stock TPI, SLP 1 3/4" headers, no cat, Dynomax cat-back, Stock PROM
E.T.F.A Member #11
Old Mar 15, 2001 | 07:34 PM
TunedPort350's Avatar
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
'91 GTA 350 TPI with 26,000 original miles, bone stock right down to the AC/Delco spark plugs.
[This message has been edited by TunedPort350 (edited March 15, 2001).]
Old Mar 15, 2001 | 08:58 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Would I settle for anything less? I'll give you one guess to the color.
"Pray to God, but at the same time use your hands"
-Greek Proverb
Old Mar 15, 2001 | 09:52 PM
GTAMAN63's Avatar
51,000 miles. Put almost 10,000 on it in 8 months, this baby's driven!!
Barry Izold
89 T/A, GTA
Modified 350/T-5
[This message has been edited by GTAMAN63 (edited March 16, 2001).]
Old Mar 15, 2001 | 10:52 PM
rondubbs's Avatar
here.
1988 GTA Trans Am 350tpi: 45k miles,3:27 BW rear, aftermarket t-tops
Hotchkis: subframe connectors & strut tower brace
Flowmaster: 3inch exhaust& dual chamber muffler
Accel: 8.8mm wires, cap&rotor, u-groove spark plugs
Edelbrock: 52mmTB, intake & runners
K&N: filtercharger
TPIS: 170* stat, afpr, mat relocation kit
March: performance crank and alternator pulleys
Hypertech: 176* fan switch
Other mods: ported plenum, gutted cat, tb coolant bypass, flux capasitor, driver side floor mat removed
Old Mar 15, 2001 | 10:55 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
YO!!!!!!!!! Check out the site... I'm here but the car still isn't running right haha Lets see how many of us there are!
'91 GTA:
www.fbody.com/members/91WS6GTA
Old Mar 16, 2001 | 12:18 AM
KenGTA88's Avatar
I got mine...
1988 Trans Am GTA
Old Mar 16, 2001 | 12:47 AM
Stormshadow GTA's Avatar
Got the 87 lb9 5 spd in the house,gta's are way cooler than ICOC'S OOPS IROCS'
Old Mar 16, 2001 | 09:20 AM
Beefy89's Avatar
I've got an 89 L98,fully ported L98 heads, plenum,runners and base,96 LT1 cam,Comp cams 1.6 roller tips,ZZ3 springs,Speed Pro 9.75 to 1 pistons,SLP 1 3/4" headers,3" Flowmaster exhaust,MSD blaster coil,Hypertech afpr,Hughes 2500 stall t/c, 327:1 gears,and a brand new pine tree air freshener.
We need Perry Mason
Old Mar 16, 2001 | 09:27 AM
Steve89GTA's Avatar
Present and accounted for!
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
Autometer Vac+Oil Temp
Old Mar 16, 2001 | 11:10 AM
Dennis_91GTA's Avatar
One Here!
91 GTA
5.7 TPI
Old Mar 16, 2001 | 11:18 AM
88GTAChuck's Avatar
One here too.
1988
5.7
61000 miles!
Old Mar 16, 2001 | 12:18 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
here!
Originating member of the SJNEP Crew "Welcome to Understated Sounds and Performance"
Rice..It's whats for dinner!
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM RiceEatinGTA***
Tony
Check out www.transamgta.com
"What does not kill us only makes us stronger"
Old Mar 16, 2001 | 02:30 PM
kwikgta's Avatar
HERE!!!
92 GTA(only 226 made)ort matched sportsman heads with 2.05 valves,64 cc,milled .015,.028 head gaskets,port matched Accel runners,port matched plenum,port matched edelbrock intake,flow matched injectors,jet hot headers and 2.5" mandrel bent exhaust,Flowmaster muffler,underdrive pulleys,slp cam,1.6 rockers,slp cold air induction,52mm throttlebody,performance resource custom chip,Dyna module,Screamin Demon coil,Accel 8.8 wires,Bosch platinum plugs,timing at 10 degrees,tb bypass,relocated map sensor,shift kit,Fairbanks billet servo,pump vane kit & 2400 stall,Torque converter lockup switch,3.42 posi with welded axle tubes,Zexel Torsen HD diff.,Summit rearend girdle,solid pinion spacer,& alloy axles.Boxed panhard bar,lakewood lca's & edelbrock strut tower brace,Jeg's torque arm,Jegs welded in subframe connecters.Performance friction pads,turbo slotted front rotors,stainless braid brake lines.Roh ZT 17x8.5 front wheels with 255/40ZR/17 tires. 17x9.5 rear wheels with 275/40ZR/17's on the street.Hoosier 26x9.5 slicks on the strip.
Old Mar 16, 2001 | 03:12 PM
theformula's Avatar
Ron Rozotti (or however you spell it), your GTA is pretty hot man. I like the t-tops
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March alt. pulley, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL (5400rpm limit),Holley 9mm wires,Ac delco R43ts plugs,stock chip,Ford SVO 24# injectors,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,180* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Mar 16, 2001 | 03:20 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
I have one of those. Click on link. Presently has 175K miles, looks like new!
1988 GTA 5.7L TPI Auto
355 ci. block,TPIS ZZ-9 Camshaft, B&M Holeshot 2400 Stall Converter, 3.73 Richmond Gears
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Old Mar 16, 2001 | 04:01 PM
rondubbs's Avatar
<font face="Verdana, Arial" size="2">Originally posted by theformula:
</font>
thanks for the compliment on my car ,, no thanks for the butchering of my last name
Old Mar 16, 2001 | 04:46 PM
87POSGTA's Avatar
Car: 1989 Firebird
Engine: 5.7 Vortec HSR
Axle/Gears: 9-bolt 3.45
Red '87 lb9 with t-tops waitin for a motor
Old Mar 16, 2001 | 04:58 PM
Just in case anyone doesn't know, here is a link to a GREAT GTA site;
http://www.geocities.com/MotorCity/Downs/9635/
Old Mar 16, 2001 | 06:05 PM
MrMike99's Avatar
I love my car. Mike
90'GTA L98
Blk/Blk leather
355-4 bolt aluminum heads
10/1 forged pistons
comp cams 510 lift 320/330 @.050 114 LSA full crane gold RR,
1 3/4" SLP headers
ported lower/SLP runners 52mm TB, 24# SVO inj.
T700R4 rebuilt by ME.
all the trick stuff. superior shift kit. Fairbanks 9 clutch-noburn/.5" TV boost/Vette servo/Kevlar band/all new bushings etc.etc.etc.
Old Mar 16, 2001 | 06:07 PM
Voodoofighter's Avatar
'88 Notchback 350 owner here!
'91 Formula L98-Soon to be T-RAM'd
'89 Trans Am
'88 GTA Notchback L98
'87 IROC L98
Previous cars:
'88 Trans Am
'87 Trans Am
'87 Formula
'86 Trans Am
Old Mar 17, 2001 | 12:08 AM
Jon88GTA's Avatar
Flame Red 1988 GTA, L98/auto, 98k on the odometer. Only 2 previous owners, one of only 5 cars built in '88 with RPO U21. Built early in the model year (November 6, 1987), so it has some 'unique' features: no VATS, and it has the radiator, coolant hoses, and external ignition coil from a 305. I've put almost 15k on it in the less than 2 years I've owned it! Only major mod is a cat-back that the previous owner installed.
Old Mar 17, 2001 | 02:37 AM
Crusader's Avatar
Car: 1988 Firebird Formula
Axle/Gears: 3.45
'88 5.0 Auto here.
Jess
1988 GTA - 5.0 Auto
- TPIS Air Foil
- Hyper Tech
- Flowmaster
- 160* thermostat
1989 Firebird - For sale!
My Page - <A HREF="http://transam.freeservers.com
Firebird" TARGET=_blank>http://transam.freeservers.com
Firebird</A> owners go here - http://www.transamgta.com
Old Mar 17, 2001 | 08:16 AM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
I got one!!
89 GTA 350 T-Tops White/Grey----Looking for a little more performance than stock!
Old Mar 17, 2001 | 08:50 AM
F22Raptor's Avatar
'88 GTA 350 Full of Leprosy (rust)
Full exhaust, free mods, Xtreme energy cam, intake pieces and 2100 RPM TQ
13.39@102.50 MPH
1.90 Sec ----- Best 60FT
104.23 MPH -- Best Trap Speed
AIM HIGH!
Old Mar 17, 2001 | 09:16 AM
shawn87gta's Avatar
87 GTA, auto w/2100 stall, 3.27 rear, L98 .020 over,Comp 269HR cam & 1.5 roller tips, ported heads, 52mm TB & airfoil, siamesed SLP runners, port matched plenum, ported intake, Edelbrock TES, AFPR, MSD 6A/Blaster coil, MAF screens, cold-air induction, heated O2, Ed Wright Fastchip.
Soon: ported/polished: Super Ram, Accel intake, Sportsman II's w/1.6 rr's - & burning my own proms.
[This message has been edited by shawn87gta (edited March 17, 2001).]
Old Mar 17, 2001 | 11:40 AM
Beefy89's Avatar
Thanks GTAMAN63
[This message has been edited by Beefy89 (edited March 19, 2001).]
Old Mar 17, 2001 | 01:55 PM
Ricky Bettinger's Avatar
<font face="Verdana, Arial" size="2">Originally posted by black5.7GTA:
</font>
1990 black on black GTA 5.0 5-speed.
Old Mar 17, 2001 | 03:43 PM
GTAMAN63's Avatar
Beefy89,
You need to upload your image to the internet first. You can go to http://www.photopoint.com to do this. Once it is uploaded click on "link to this image" (at photopoint) and copy the link to your last post. You need to add img with brackets before and after your link. Click the edit button on my previous post above to see how the link should look. That's it!!!
Barry Izold
89 T/A, GTA
Modified 350/T-5
[This message has been edited by GTAMAN63 (edited March 17, 2001).]
Old Mar 17, 2001 | 04:23 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
HERE!! Man, I love these car's !!!!
Always runnin WFO!! Later GTA .... 92 to be
exact......
Old Mar 17, 2001 | 04:31 PM
88TAGTA's Avatar
1988 5.7 gunmetal, 139,000 miles, original owner.
Old Mar 17, 2001 | 08:02 PM
smithtc's Avatar
I Love My GTA...and plan on purchasing two more (TTA, and 5 speed)
Gunmetal 89GTA T-Tops L98
700R4 with 3.27 gears, street tires
Best 60 ft: 1.996
Best 1/8th mile: 9.02 @ 76.5mph with 60' time of 2.14
Mods: air filter, hypertech chip, 3" exhaust (no cat.)
Current Mods: 8.8wires, cap, rotor, +4 plugs, MAF screens, Servo, custom Ram Air, TPIS air foil, and some tuning
Going to the track this weekend...hopeful for improvements.
Old Mar 17, 2001 | 08:50 PM
GTA Notchback's Avatar
Car: 88 GTA Notchback
1988 Flame Red GTA Notchback.
3rd owner
All stock with 5.7 and 166xxx miles.
Still runs and looks new.
Old Mar 17, 2001 | 09:36 PM
JAY87GTA's Avatar
I'm here. 350, 116,000 daily driven miles, "porsche" style mirrors.
[This message has been edited by JAY87GTA (edited March 17, 2001).]
Old Mar 18, 2001 | 10:41 AM
cc rider's Avatar
Count me in .1991 GTA -ARTIC-WHITE -no CD, no T-tops.98,000 one owner miles.
Old Mar 18, 2001 | 02:24 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Yup.
Old Mar 18, 2001 | 06:19 PM
bulldoggta's Avatar
-91 GTA, 5.7, 119,000, runs well, ....except rear Hatch motor no longer will lock the Hatch, PITA. Fuses and wiring good. Any help out there, or recommended 3rd Gen Mech in Tampa area??
Old Mar 18, 2001 | 07:57 PM
GTAMAN63's Avatar
Bulldog,
I had lots of problems with my power hatch. When the gears finally stripped I converted it to a manual latch. I had someone compress the gasket by leaning on the hatch and marked 2 holes on the rails inside the power hatch box. I then drilled out the holes and used two bolts with locking nuts to hold the rails in place. It doesn't take much to close it (no slamming, just like closing a trunk) and the power hatch release still works!! It may not be as cool, but it was a free fix. Unless I run into excess money, I'm keeping it the way it is!
Barry Izold
89 T/A, GTA
Modified 350/T-5
Old Mar 18, 2001 | 09:18 PM
  #42
5.0GTA's Avatar
YEAH CRUSADER! BE PROUD TO BE THE ONLY OTHER PERSON HERE WITH A 5.0 AUTO!! yeah buddy! '88 305/auto IN DA HOUSE! hehe
1988 Pontiac GTA 5.0 TPI
-K&N Filter
-Hypertech Air Foil
-Hypertech Perf. Chip
-2.5in Flowmaster Muffler
-Catco Hi-flow Cat
15.32@88mph
2.077 60-ft.
Kills
94 Probe GT, 95 Mustang GT, 96 Impala SS, 85 Thunderbird 5.0, 95 Accord V6, 98 Integra VTEC, 70 Chevelle Malibu, CRX w/ Turbo and Intercooler (have it on tape to prove it)
Old Mar 19, 2001 | 12:27 AM
  #43
Transformer's Avatar
88 GTA
88GTA 5.7(under construction) ATI Procharger,58mmTB,ported plenum,SLP runners,Edelbrock HI-FLO base.ported heads,1.5RR,210/220/480 compcam,AFPR,SLP1 3/4 headers,3.70 gears,Eibach drag launch,Lakewood LCA`s, Nitto drag radials.
Old Mar 19, 2001 | 11:47 AM
  #44
Flfinn's Avatar
Car: GTA '88
Engine: 420 Dart SHP
one here!
-88 GTA 305TPI/T5, 3.45 posi, Crane cams 2032, Edelbrock TES #6872, 3" cat-back, ported+portmatched heads, base, plenum, multiangle valve job, no cat, no air, Haltech E6GM ECM. http://www.helsinki.fi/~kjilehto
[This message has been edited by Flfinn (edited March 19, 2001).]
Old Mar 19, 2001 | 12:15 PM
  #45
Chet's Avatar
Car: GTA
Me too!
88 GTA L98 SSM frame connectors Hotchkis STB ADS Offroad chip Transgo shiftkit All free mods
85 T/A LG4 WS6 Stock
Old Mar 19, 2001 | 01:53 PM
  #46
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Got my "unique" GTA.
Check out "transamGTA.com" for some nice looking GTA's also.
'91 GTA with TPI 350 & T-Tops. Just a few mods, if you want to find out just line up next to me at a stoplight!
Added bonus:
Wife's car is a '00 Grand Prix GTP!
[This message has been edited by blacksunshine'91 (edited March 19, 2001).]
Old Mar 19, 2001 | 07:39 PM
  #47
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
Another proud owner here!!!!!
Veiw MY CAR at:
http://www.members.tripod.com/~btessier
88 GTA
L98 350
700R4
3:27 axle
MODS,
Edelbrock TES headers, 2.5" straight pipe, Flowmaster 80 series, K&N filter, Accel 8.8mm wires, Bosch Platinum plugs, Wells cap and rotor button, Wells ignition module, MAF screens removed, Hypertech TB air foil, Thermomaster stage II chip, 180* Powerstat, Hypertech cool fan switch, B&M shift kit, B&M power clutch pack, B&M servo, GM fuel filter.
Old Mar 20, 2001 | 07:13 AM
  #48
Ozzy88GTA's Avatar
Engine: 5.0 TPI
Transmission: TH700-R4
We are still coming!
89K, 305 auto, marron, black interior
Old Mar 20, 2001 | 09:23 AM
  #49
ChrisR's Avatar
ME TOO!
1987 GTA 350,rebuilt in 1998. new heads, Heddman headers w/y-pipe, Dynomax cat-back system, 45,000 coil, accel plug wires and cap&rotor, k&n, b&m shift kit and trans cooler, modified mass airflow sensor, manual fans switch. MSD 6A yet to be installed. No time slip.
1993 Bonneville SSE ALL STOCK. 98,xxx miles and stil counting...plan to install K&N and Flowmaster 80 series
Old Mar 20, 2001 | 10:12 AM
  #50
MY87GTA's Avatar
'87 GTA 350, 5 speed, Black on Black Here
