Cold start injector?
Old Apr 13, 2001 | 09:58 PM
85ZZ4TPI's Avatar
I think my cold start injector is leaking fuel. My car runs rich all the time and fuel pressure wont correct it. My injectors are orig 305s and they are rebuilt and matched. Cold start is orig. 164000 rounds! I have heard you can eliminate it. I dont drive in the winter, What is needed? Thanks
ZZ4 crate motor,Stock tuned port,afpr,700R4 art carr shift kit,3.42 posi drums,Eibach pro kit,poly bushings throughout,yadayadayada
Old Apr 13, 2001 | 10:15 PM
Vader's Avatar
85,
Remove the fuel line fitting from the left rear fuel rail, and plug the opening. The remainder of the cold start valve can stay in place without causing any problems. If you really wanted to, you could remove teh cold start injector and fabricate a blockoff plate for the opening. You could also remove the cold start and test it with fuel pressure to test your theory. If the cold start is not leaking, start looking at the oxygen sensor.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 14, 2001 | 01:35 AM
88 trans-am's Avatar
Call Jegs and ask for a cold start block of kit made by Accel. It's about $60 wich is cheaper than a new cold start injector and makes alot neater job.
Mike s
Old Apr 14, 2001 | 08:22 AM
88 IROC BOB's Avatar
Can you still use the runners that have the provision for the cold start valve even if you block it off?
350 TPI, 700R4(rebuilt), K&N's, MSD 6AL, Headers, Flowmaster, 160* stat, airfoil, MAF screens cut out. 13.88 @ 101.18 mph
Old Apr 14, 2001 | 10:30 AM
yes, the block off kit has the plug for the cold start valve and a plug for the fuel rail. Leaving the cold start valve in is ok ,but I recomend that you get the kit mainly for the fuel rail plug. Just tring to plug the fuel rail with a bolt will not work, becouse their is a o ring that is needed for it to seal.
Mike s
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
