valvetrain question
Old Apr 14, 2001 | 05:55 PM
jsbz's Avatar
valvetrain question
I have a 88 IROC 350 with stock heads removed.I have a set of Dart Sportsman II heads with studs and guideplates.On the stock heads I have self aligning roller rockers.Can I use these on the Darts?Also what pushrods do I use?
Old Apr 14, 2001 | 07:00 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
First to answer your question about the pushrods!! You MUST used hardened (heat treated) push rods with guide plates! Always!!
To answer your other question, you CAN use the self aligning rockers but you don't NEED to use them!! Self-aligning rockers are used when the heads have been drilled for guide plates but no guide plates are used or in a roller engine with no guide plates!! The rockers must always have a way to align...either with self-aligning rockers or with guide plates!! So if you have guide plates then you don't NEED the SA rockers but it doesn't hurt to use them!
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
