Will it work?
Old Apr 14, 2001 | 11:50 AM
Cam350TBI's Avatar
Will it work?
I am looking at buying a TPI unit from an '87 T/A to replace my TBI unit now on my '88 Camaro. Will it work? Which years are the "old years" where the "old" TPI units will not work on my '88 Camaro engine? Please help!!
Old Apr 14, 2001 | 06:55 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I believe '88 is the cut off!! In '88 GM changed the TPI setup a bit and I could be wrong but I don't think the '87 TPI setup will work with your '88!! Call GM and ask them, they'll be able to tell you for sure!!
Old Apr 15, 2001 | 10:46 AM
Vader's Avatar
Cam350,
The TPI should bolt on, but the '87 and older TPI units have a provision for the cold start injector, whereas '88 and later TPIs eliminated the cold start in favor of cold enrichment through the eight service injectors.
You'd have to get a PROM for an '87 to use the cold start valve and system, but the rest should work the same.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
