Best 1.6 Full Roller Rocker the fit under stock covers?
Old Apr 10, 2001 | 09:12 PM
Night Hawk's Avatar
What 1.6 full roller rockers fit under stock L98 valve covers with stock L98 heads? What are the best, and what are the best bang for the buck, but still reliable 1.6 roller rockers.
Old Apr 10, 2001 | 11:41 PM
theformula's Avatar
I use Crane Cams race gold 1.6 full roller rockers. They run around $300 new from JEGS. I bought them off a friend for $180. I love them. They fit under stock valve covers, and later my chrome ones with no modifications done.
91 Formula 1LE 1 of 46
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 supercharger, Ford SVO 24#injectors, Crane AFPR,SLP airfoil, ported/polished plenum, March alt. pulley,Crane Gold 1.6rrs,MSD coil,MSD6AL (5400rpm limit),Holley 9mm wires,Ac delco R43ts plugs,custom chip,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,180* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Apr 11, 2001 | 12:42 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
No offence to anyone running the Crane Golds, but they are a rip-off. Buy some Harland And Sharpe roller rockers. They are just as good if not better then the cranes, cost less, and thats what Top Fuel Dragsters run. if its good enough for them, its good enough for your car too IMO. Summit carries them.
Old Apr 11, 2001 | 12:31 PM
craiger's Avatar
I just put a set of comp cams magnum roller tip rockers on my Z. They were just under $200, make sure you get the self alighning ones.
Old Apr 11, 2001 | 01:04 PM
F22Raptor's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 88blkiroc:
No offence to anyone running the Crane Golds, but they are a rip-off. Buy some Harland And Sharpe roller rockers. They are just as good if not better then the cranes, cost less, and thats what Top Fuel Dragsters run. if its good enough for them, its good enough for your car too IMO. Summit carries them. </font>
Do they have self aligning rockers? If so, thanks for the advice. Crane is surely ripping off a bunch of people.
Rick
Old Apr 12, 2001 | 05:38 PM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
GMPP sells the LT4 rockers for a bit less than the Cranes. They are made by Crane and are identical to the 1.6 Gold Races, except for color.
Bob '89 Ram Air Formula 350
Last(lost)Member of the Elusive Great Lakes Crew
My car's homepage
Old Apr 15, 2001 | 04:12 PM
KevinP92Z's Avatar
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
Hey RCR, just a note on the GMPP rr's vs the Crane Golds. I too was told by Crane and a tech at GM Customer Assistence Center that hey were the same except for the gold anodizing on the Cranes and the clear for the GM p/n's, and the Crane logo on the tips vs the Chevy Bowtie (unless you had the true LT4 blue rr's with the 7/16" studs). However, there is ONE major difference that may have just cost me some valve guides.
Depending on your cam, and in my case, head geometry (I'm running TF twisted wedge heads), the slots in the rockers are not the same. The GM p/n's are at least an 1/8th inch shorter on each end of the slot. All 8 of my intake rocker slots contacted the hex on the polylocks when the valves closed. I just put the Golds back on this weekend to fix this.
When I get the film developed this week, I'll scan and post a pic of the two rockers side by side.
Now the GM p/n's are for my wife's car since her cam lift and head geometry is not critical like mine.
KevinP92Z
92 Z28 383 SLP cam,SLP headers,SLP 2ontheLeft,Trick Flow TW heads & pistons,Edelbrock base,Accel SuperRam,52mmTB,Scat Crank & forged ConnRods,MSD 6AL,SLP convertor,Baer 13/12" Track,Moser axles,Hotchkis,Genuine GM 3.42s,SLP HD Torsen,17x9" chrome SS rims
96T/A w/SLP Ram Air,SLP 2ontheLeft, Bilsteins, Baer, Hotchkis, Genuine GM, Torsen
76 4X4 Blazer 400TPI project
Old Apr 15, 2001 | 06:10 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
<font face="Verdana, Arial" size="2">Originally posted by craiger:
I just put a set of comp cams magnum roller tip rockers on my Z. They were just under $200, make sure you get the self alighning ones.</font>
You don't need self aligning roller rockers if your heads haven't been drilled for guide plates or if you are using guide plates!! The only time you would need SA roller rockers is if you have the heads drilled for guide plates and decide not to use them....OR if you have a roller engine...then you should use SA roller rockers!!
Jeremys87
Jul 14, 2022 09:08 PM
customblackbird
Aug 15, 2021 10:16 PM
midge54
Dec 27, 2019 04:14 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
mustangman65_79
Aug 8, 2015 01:18 AM
