fuel pump?
Old Oct 28, 2007 | 06:42 PM
bsherrin01's Avatar
Car: 1985 Z28
Engine: TPI 305
Transmission: factory automatic
Axle/Gears: factory
fuel pump?
i have an 85 Z28 with a 305 TPI. i think my fuel pump is bad. its an electric, in tank pump and when u turn the ignition on no sounds are made. i know most electric fuel pumps make a sound when the ignition is turned on. is there a fuse for the pump and if so where might it be? any suggestions?
thanks!
Old Oct 29, 2007 | 12:24 PM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
Re: fuel pump?
The fuel relay could be bad, and yes it could be the fuse. I'm not in a position right now to help you find the fuse, or I would.
I highly recommend you do a search on a Helms manual and get yourself one. It's not like a Chiltons or Haynes, it's what the dealer would have if it was working on your car.
Old Oct 29, 2007 | 12:41 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Re: fuel pump?
Have a 1985 GM Camaro Service Manual for sale in the Misc. Third Gen Stuff section of the classified board. On the first page about half way down. Check it out! Badman
Old Oct 29, 2007 | 12:47 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Re: fuel pump?
Relay info and pics from manual.
Old Oct 29, 2007 | 12:56 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Re: fuel pump?
Maybe this will help.
Attached Thumbnails fuel pump?-help-fuel-d-001.jpg   fuel pump?-help-fuel-d-002.jpg   fuel pump?-help-fuel-d-003.jpg
Old Oct 29, 2007 | 12:57 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Re: fuel pump?
Last one. Left click once on pics to enlarge.
Old Oct 29, 2007 | 04:36 PM
jamesbob02's Avatar
Car: 92 Z28
Re: fuel pump?
That's a good price ($50), which is at least as good as you'd find anywhere else. You ought to take it off his hands; you won't regret it.
Old Oct 29, 2007 | 06:20 PM
bsherrin01's Avatar
Car: 1985 Z28
Engine: TPI 305
Axle/Gears: factory
Re: fuel pump?
thank you for your time! u have been a great help!
Old Oct 29, 2007 | 06:23 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Re: fuel pump?
I've lost the pump relay on a couple cars over time and thought it was pump.
the relay beside it is interchangeable to swap for test.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
