lt1 cam out of impala
Old Oct 28, 2007 | 08:08 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
is the cam in the impala lt1 the same specs as a trans am? Im looking for a cam upgrade for my 87 305tpi for under $100. i like the zz4 but i just want to drop the cam in with out clearance probs so ill have to steer clear of anything over .470 lift w/1.5 rockers thanks.
Old Oct 29, 2007 | 02:30 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: lt1 cam out of impala
depends on the year of your car and if its a stick or auto which decides which cam you have now. if you do not have the L98 cam then the LT1 cam will make a difference if you do have the L98 their should be very very minimal if anything gained.
Old Oct 29, 2007 | 06:19 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
The Impala has a smaller cam than the regular LT1. It was ground to get the boxcar body moving. Same cam is in the L31 Vortec pickup 96-99 or so. You can do a lot better with LT1 vett or F body cam.
Impala 191/196 418/430 grind 779 not much.
F and Y LT1 (95) 201/208 447/459 grind 705 much better.
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
IROCZ1989
Sep 4, 2015 11:54 AM
Strick1
Sep 4, 2015 07:11 AM
