Fact or Fiction
Old Apr 19, 2001 | 10:28 PM
bowtiez's Avatar
Fact or Fiction
Chevy mchanic told me you have to keep trouble codes clear as old stored codes can cause computer control operating problems. Anyone ever heard of this?
Bill
Old Apr 20, 2001 | 12:14 AM
theformula's Avatar
I'm not exactly sure what he meant. But some codes will put your car in "limp home" mode which is a mode to get you home.
Other than that I can't think of anything else.
Old Apr 20, 2001 | 08:25 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Fiction, the codes will self erase after so many normal cycles (i forget how many though.. I think 50)
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
Old Apr 20, 2001 | 11:39 AM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
I'm a Chevy mechanic...I know some newer cars are like that, but I'm not sure about thirdgen's. I suppose a TPS low voltage code or one along those lines would certainly affect the ECM.
Old Apr 22, 2001 | 08:59 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Fiction.
When the computer sees a a problem, it sets a "current" trouble code. When the fault goes away, the code becomes a "history".
The computer will erase the "history" codes after so many ignition cycles w/o seeing the fault again. They are totally benign. The computer only acts "funny" when there is a "current" codes set, like a code 42 or so. Once it goes into history, its back to normal operation.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Nighthawkf-117
Sep 24, 2015 02:47 PM
reactor60
Sep 22, 2015 01:44 PM
Rally Smith
Sep 14, 2015 06:59 PM
Fox118
Sep 12, 2015 09:29 PM
Street Lethal
Sep 7, 2015 01:09 PM
