Bolt Size question....
Old Apr 23, 2001 | 08:03 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
Ok, stupid Q here... I am putting my car back together (finally) and as careful as I thought I was to put all the bolts in one place I still lost at least two.... the one for the front of the fuel rail just behind the connections to the fuel lines, and the one closest to the bottom of the front of the block holding the power steering pump bracket. I can't find those damn bolts anywhere and I'm not too good at just looking at some threads and being able to tell what size they are... can someone help me out?
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
Old Apr 23, 2001 | 02:48 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
fuel rail bolt is a long bolt about 2" with a 10mm size head
power steering should be a 9/16" short bolt about 1" long
Webmaster: www.IROC-Z.org
Old Apr 23, 2001 | 07:18 PM
Guest
Guest
Posts: n/a
The one going into the block by your power steering is a 3/8" coarse thread bolt, I think its 1 1/4" long. Thats something you can check easy, just measure how long the hole is in the bracket, and add at least the thickness of the bolt to that to get your size. I think the holes in the block are around 3/4-1" deep.
The one for the fuel rails you are talking about I am pretty sure is 3/8" coarse as well, its only about 3/4" long. I can check later to make sure thats the right size if someone else doesnt know for sure.
Old Apr 23, 2001 | 07:58 PM
Car: 1985 Trans Am
Thanks Max, I called the dealer and they had the bolts in stock. They didn't say what size they were, but that they were both the same exact bolt and I went down and got them... they look like 3/8", but then again like I said I'm no good at eyeball measurements.... Thanks a lot to both of you for your responses.
Old Apr 24, 2001 | 04:02 AM
Engine: 305TPI
madmax, i thought most of the bolts in the TPI setup were metric? if that's the case shouldn't it be M10 or somewhere in that league?
for the record, Kevin: when i said 9/16" i was referring to head size, the threads would be as madmax said, 3/8.. sorry to confuse you both
Old Apr 24, 2001 | 07:05 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
I know the one for the fuel rails is metric and it's pretty short. Only about 3/4"
Old Apr 24, 2001 | 09:29 AM
Guest
Guest
Posts: n/a
For some reason I am thinking that one isnt metric. The dist mount, and the 2 for the thermostat are standard. I think the EGR ones are too. Ill have to go check this later to be sure...
Old Apr 24, 2001 | 09:41 PM
Guest
Guest
Posts: n/a
I checked, they are standard not metric. EGR too, its 5/16". Typical, cant stick to one or the other, gotta mix+match.
Old Apr 24, 2001 | 10:30 PM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
From what I've noticed, our cars tend to have metric fasteners everywhere except for the heart of the drivetrain. Engine block, heads, and the fasteners that attach to those seem to have been carried along as standard fasteners for many years after every other part of the car went to that gawdamn communist metrik abortion. As you move away from the block and heads you begin to encounter metric fasteners.
Old Apr 26, 2001 | 04:44 AM
Engine: 305TPI
i guarantee the fuel rail is metric
Old Apr 26, 2001 | 08:34 AM
JoelOl75's Avatar
I could guarantee that too because I tried to replace the standard one with a stainless (from my collection) SAE and none would go. It's not 5/16 NC or NF or 3/8 either.
Old Apr 26, 2001 | 09:12 AM
Guest
Guest
Posts: n/a
I can guarantee you are both thinking of the 4 that hold the fuel rails down, which are metric. The one in front isnt metric.
Old Apr 26, 2001 | 09:19 AM
Car: 1985 Trans Am
Max is right... it's 3/8".... both of them. The one for the front of the fuel rail and the one for the power steering pump bracket are the same. Thanks for all your help.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
gixxer92
Sep 1, 2015 04:32 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
knight72
Aug 10, 2015 09:32 PM
