1989 CAMARO IROC-Z FUEL GAUGE PROBLEMS
Old Nov 11, 2007 | 03:50 AM
wicho's Avatar
Car: CAMARO IROC-Z
Engine: 350 T.P.I
I AM HAVING PROBLEMS WITH MY FUEL GAUGE IT GOES DOWN WHEN I BRAKE AND UP WHEN I ACCELERATE IT GOES UP I HAVE BEEN LOOKING AROUND BUT THEY DO NOT GIVE ME A GOOD ANSWER THEY JUST SAY ITS A PROBLEM AND THE LESS GAS THE MORE THE NEEDLE MOVES WHAT CAN I DO TO FIX THE PROBLEM IS IT THE GAUGE OR SOMETHING IN THE TANK THANKS
Old Nov 11, 2007 | 04:07 AM
thefightback's Avatar
Car: 86 Z28
Engine: '90 350 TPI
Transmission: T700
Re: 1989 CAMARO IROC-Z FUEL GAUGE PROBLEMS
I thought this was pretty normal with old cars, happens on my 86. Just the float moving around i assume, and obvioulsy the less fuel, the more it can move. Correct me if im wrong though...
Old Nov 11, 2007 | 05:31 AM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
mine does it to im assuming its lack of baffling in the tank or something like that
Old Nov 11, 2007 | 09:55 AM
MP81's Avatar
Car: 2007 Cobalt LT
Engine: M62'd 2.2L L61
Transmission: 4T45E 4-speed Automatic
Axle/Gears: Stock
Yeah, mine does this as well. It's annoying, but I've gotten used to it.
Oh, and by the way, how about next time you post, please don't type in all caps, and use some form of punctuation.
Old Nov 11, 2007 | 10:25 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
it is normal for most cars. it doesn't have to do with baffling. it is the float in the tank moving with the movement of the fuel. you brake-all the fuel rushes forward and allows the float to go down(float is near the back of the tank). when you accelerate- fuel rushes to the back of the tank raising the float. it's pretty typical.
Old Nov 11, 2007 | 12:06 PM
Brennan's Avatar
but wouldnt baffeling limit the fuels movement in the tank abit or at least slow it down enough to reduce the movement in the gauge?
Old Nov 11, 2007 | 03:12 PM
tekkitan's Avatar
Car: 87 IROC-Z
This doesn't happen to mine, I guess mine isn't normal then? :-)
Old Nov 22, 2007 | 05:15 AM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Mine does this too, had for a while, always heard it was the sender, well i got a new gauge one day and it still did it but not as bad, it doesnt do it a little when braking it sometimes it will go down to almost the E mark, But, I just had to have a gas tank leak fixed so while the tank was out I had them replace the fuel sending unit, but it still does it : ( Its really annoying, if anyone figure this out please tell me
So yours pretty much just goes down as it should and never goes down some and then back up??
Old Nov 22, 2007 | 10:45 AM
tekkitan's Avatar
Car: 87 IROC-Z
Yep. Works perfectly.
Ghettobird52
Jul 5, 2024 11:18 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
justin57
Aug 20, 2015 07:05 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
antares57
Aug 6, 2015 07:47 AM
