Code 33 need help. I've tried everything
Old Nov 11, 2007 | 11:25 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Hi, my car is giving me code 33, and I fallowed GM service manual to diagnose this code, and it told me to replace the maf sensor. I checked with my scan tool and it showed me the ecm was reading 17 gm/sec @ 950 rpm , at the same time my rpm gauge was showing ~1500 rpm. When I searched on TGO, I found out that I suppose to have 7~8 gm/sec at idle. Then, i scanned my 97 350 maf Vortec truck to compare it to the Camaro, and the truck was reading about 17 gm/sec at idle also. Now I am confused is my maf bad or what? I do not want to spent $200 on maf sensor and it may not solve the problem..
car's background: 85 TPI 406 ci, Super Ram. cam Dur 224 224 @.050 Dur Adv LSA 114. ECM is converted to 165 from 870. Maf is stock from 85 . E6 broadcast and the only thing modified in the chip is the fuel injectors constant to compensate 30lbs injectors. Also the car been sitting for a year. Thanks in advance
Old Nov 13, 2007 | 12:59 AM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Re: Code 33 need help. I've tried everything
let me ask this, how much gm/sec should i get if the maf is disconnected and ignition on / engine off?
Old Nov 15, 2007 | 09:05 AM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
anybody? is it a hard question or what??
Old Nov 15, 2007 | 12:19 PM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
Without actually check I would image you should get 0 gm/sec or close to that with the car not running.
When you had the scan tool hooked up and got 17 gm/sec @ 950 was this at idle or at 1500 rpm. Your original post is confusing, you were getting two different rpm readings so which one was correct?
Old Nov 15, 2007 | 10:23 PM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
it was 17 gm/sec@ 950rpm
Last edited by 400Z28Racer; Nov 15, 2007 at 10:24 PM. Reason: Automerged Doublepost
Old Nov 16, 2007 | 12:04 AM
armygreen87's Avatar
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Transmission: 4-speed automatic
Axle/Gears: 2.77
I once had a code 33 on my Iroc. I replaced the MAF but I didn't see much of a difference so I had my timing adjusted using the distributor which helped me out a lil. I don't know exactly what the timing is supposed to read, I just adjusted it until it ran better, lol. Also, check your spark plugs and wires to make sure they are all good because that could cause a code 33, I think. Since you've had the code 33, has the car done anything abnormal, like surging or running rich?
Old Nov 16, 2007 | 11:22 AM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
well my timing is set at 10 deg, and i think that's what it supposed to be at. my car was surging, and running very rich. I also replaced my plugs.
Old Nov 16, 2007 | 11:52 AM
vbMike's Avatar
I believe the timing is supposed to be set at 6* from the factory.
Old Nov 16, 2007 | 12:19 PM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
I'll adjust it to 6 deg, but I do not think it will make a difference for code 33
Old Nov 21, 2007 | 10:07 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
You're right it won't.
Old Nov 22, 2007 | 11:00 PM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
I got it, my burn off and maf power harnesses were connected to the wrong relays. Here is a flow chart for code 33 just in case if anybody needs it
db057
Jan 10, 2020 08:55 PM
BumpaD82
Feb 26, 2016 02:57 PM
AussieZ28
Sep 30, 2015 03:36 PM
Racerx974
Sep 19, 2015 10:16 AM
3rdgenkindagal
Sep 13, 2015 02:02 PM
