thin head gaskets for my S/R torker heads a few ?'s
Old May 2, 2001 | 07:57 PM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
i spoke to my local speedshop owner (guru) and he informed me that felpro makes a thin .015 compressed head gasket, to help me regain a the compression that i might lose when i put my 67cc chamber heads on my L98 TPI whats your opinion of these gaskets...r they still reliable for everyday driver?. he estimates i will go from 9.3 to 9.0 compression with the S/R torker heads and that would save me the trouble of milling them. need second opinions.... i really dont want to mill them by the way he said that the torkers r an xcellent choice for my application. headers and 1.6 comp cams rr's are also in order for next week...
Old May 2, 2001 | 08:02 PM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
oops
white/gold GTA ,leather 5.7TPI 700r4 3:27posi twin cats,3"catback,aluminum d.shaft ported plennum,afpr,8mmwires,k&Nand all other "free" mods, performance resource chip,SLP cold air intake.
Old May 2, 2001 | 09:50 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
going from 58 cc's to 67 will drop you around .9 1 cc=.1 in compression going with a thinner gasket will help but you'll only be about 8.6 to 1
Old May 3, 2001 | 06:41 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Hey Eddie, I'm using that gasket on my 305H.O. with no problems whatsoever. Felpro's gasket is coated, and if you spray the gasket with Loctite Ultra-copper spray-a-gasket, you wont have to worry about it leaking ever.
One thing that's critical with this gasket is the preparation of your deck and your cylinder head surface: They must be smooth. Some machine shops will deck such that you have ridges in the material for "bite". Ask that they machine as smooth as possible. There's a note in the gasket pack that specifically describes the finish required.
One last thing: Even the 305H.O. and 305TPI motors came with steel head gaskets, straight from the factory, so I think that reliability is not a big concern.
Old May 3, 2001 | 07:07 PM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
my L98 heads have 64cc chambers stock(not 58) and the S/R torkers have 67 cc chambers. do u have the part numbers for those thin gaskets??
thanks
Old May 3, 2001 | 07:09 PM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
also....where did u get the "spray-a-gasket"?
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
