TPI Bolts ?
Old Nov 15, 2007 | 11:44 AM
hzemall's Avatar
TPI Bolts ?
I am doing the TPI swap in my Regal but I want to use all ARP fasteners to match what I have currently.
Does anyone know where to get a list of all the sizes of the bolts for the whole TPI top end ? I really don't want to buy one of those stainless kits just to measure them all to get the sizes.
Old Nov 15, 2007 | 01:22 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: TPI Bolts ?
Either Summit or Jegs sells an ARP TPI bolt kit (non-stainless). I purchased one last fall. Check out their websites.
Hope this helps!
Almost forgot... TPI Parts also sells nice bolt kits...
http://tpiparts.net/82_92_bolts
Last edited by formula_novice; Nov 15, 2007 at 01:23 PM. Reason: Automerged Doublepost
Old Nov 15, 2007 | 08:32 PM
hzemall's Avatar
Re: TPI Bolts ?
The only kit ARP makes is for the intake manifold. I want to replace all the other ones as well.
Old Nov 16, 2007 | 07:22 AM
Re: TPI Bolts ?
Then use the TPI Parts kit. I've used both and like the TPI Parts one better... the heads on the ARP's tend to strip easy.
Plus the ARP kit is 34 bolts... i don't think it takes 34 bolts to attach an intake manifold.
Old Nov 16, 2007 | 10:01 AM
hzemall's Avatar
Re: TPI Bolts ?
Do you have a part number for the ARP TPI kit you bought ?
I want the black 12 point ARP bolts, that is why I am looking for the bolt sizing of all the fasteners in the kit, I was hoping that someone had a list of what they are from a GM manual or something.
Thanks for the help.....
Old Nov 17, 2007 | 12:32 PM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
Re: TPI Bolts ?
you might want to try mocking up the manifold base to the heads with the ARP bolts. I noticed when I put my SLP runners onto my Edelbrock TPI base, the GM pan-head style torx bolts luckily provided enough clearance for me to wiggle the runners into location, it is a very tight clearance, and I'm not sure if that was the reason for the factory low-clearance round head bolt style choice instead of the traditional GM hex head bolts.
Old Nov 17, 2007 | 08:23 PM
billydonn's Avatar
Car: 66 c-10 stepside
Transmission: TKO 600
Re: TPI Bolts ?
-All the bolts that hold the TPI together are metric, while manifold to engine bolts are 3/8 x 16 with torx t-45 head.
-Runner and upper plenum bolts are torx t-40.
-Throttle body are 10mm shoulder bolts.
-TPS bolts are torx t-20.
Old Nov 17, 2007 | 08:53 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: TPI Bolts ?
A replt to this post has a scanned image of parts list.
https://www.thirdgen.org/forums/tpi/...tance-tpi.html
Old Nov 19, 2007 | 09:23 PM
Re: TPI Bolts ?
I'm not trying to be difficult or an a**, but wouldn't it be easier & faster to just order the kit from TPI Parts?
My personal experience with ARP bolts is the heads strip easily. You are wanting bolts for the TOP END... not exactly load-bearing stuff.
Old Nov 19, 2007 | 11:23 PM
hzemall's Avatar
Re: TPI Bolts ?
Hard to explain but I am very **** about the details and I want the ARP to match all the other ARP that I am using.
evilstuie
Jan 9, 2020 08:29 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
