fuel pressure question
Old Nov 16, 2007 | 11:41 PM
tmviper's Avatar
hey, quick question. when it says to set your fuel pressure at 42 psi for a certain result, is that fuel pressure at idle with the vacuum line connected or disconnected? if it reads 40 at idle, and i disconnect the line to adjust it, it jumps to 50. naturally the vacuum would drop at WOT, causing fuel pressure to spike. if anybody has any feedback on this, id appreciate it.
Old Nov 17, 2007 | 01:52 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: fuel pressure question
42psi with engine off, or regulator vacuum disconnected at idle.
Old Nov 17, 2007 | 08:56 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Vacuum disconnected from the regulator and engine idling.
Old Nov 17, 2007 | 01:57 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
so what should the pressure be once the vacuum hose is reconnected?
Old Nov 18, 2007 | 06:59 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
43 ish
Old Nov 18, 2007 | 08:12 AM
Bobby_80s's Avatar
Axle/Gears: no idea
is that 43 when the hose is connected and engine running?
Old Nov 18, 2007 | 08:14 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Hose disconnected and engine running.
Old Nov 18, 2007 | 11:11 AM
tmviper's Avatar
well, ive got aq holley afpr, and if its at 40 with the engine idling, and then i disconnect the vacuum line, it jumps up to 50
Old Nov 19, 2007 | 10:53 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Set it with the vacuum disconnected because the idle is dependant on other variables.
Old Nov 23, 2007 | 10:24 PM
tmviper's Avatar
well, at idle with vacuum disconnected, its near 50psi. anyone know what the limit is on how high the pressure can go? ive got a holley fuel pump, but i would hate to blow a fuel line apart, being as the feed and return lines are stock
Old Nov 24, 2007 | 10:54 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Stock regulator will blow at 65.
Why are you so high and wanting to go higher?
Old Nov 24, 2007 | 11:00 AM
Bobby_80s's Avatar
Axle/Gears: no idea
so lets say i set it at 42-43 with hose disconnected what should it be once the hose is reconnected?
Old Nov 24, 2007 | 11:03 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
~39
Old Nov 25, 2007 | 12:22 PM
tmviper's Avatar
to answer your question, viprklr, im at 40 at idle, which im pretty happy with. when i disconnect the line, it spikes to 50. im under the impression that when the car is at WOT, it is a 50 as well. i have a holley regulator as well, but there seems to be a 10 psi difference between idle and WOT. when will the fuel feed line blow?
Old Nov 25, 2007 | 12:26 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
It'd probably take more pressure than your pump can supply to blow the feed line.
That's a big jump. My holley afpr only moves 4 psi between connected and disconnected. Maybe my low vacuum could be the reason for that though.
Old Nov 25, 2007 | 02:40 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
mine was at 45.5 with the car running and the hose connected. been that way ever since ive got the car?
Old Nov 25, 2007 | 03:56 PM
SLP-GTA's Avatar
Car: 1991 Formula (sold)
mines @ 36-38 and it won't start. doesnt it need 40plus to start??
Old Nov 25, 2007 | 07:19 PM
Eightyninef's Avatar
My factory regulator is 47 psi with the vac disconnected.
89 F motor.
Old Nov 25, 2007 | 09:57 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
22lb/hr injector pressure rating is 3 bar/43.5psi
At WOT a 22lb/hr injector should flow 22lb, but if the pressure is 38psi it's only flowing 20.5lb/hr, at 47psi it flows 22.8lb/hr.
Higher flow is preferable, but not much more than 10%.
A MAF ECM can adjust for a 10% increase either way, but the Injector depends on the pressure for good atomization and a good cone pattern.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
