got my car dynoed kinda disapointed whatcha think?
Old May 7, 2001 | 03:00 PM
bad camaro RS's Avatar
got my car dynoed at power tour fri i pulled 263.4hp @4800 and 332.1 tq@3600 at rear wheelsive got a 87 355 tpi with edelbrock base and runners afr 195cc heads comucam 2032 1.65 roller rockers 10 to 1 compression whatcha think? i was hoping for 300 rear wheels
1992 camaro RS w/ 350tpi
195cc AFR heads with compition port work milled to 58cc
1 3/4 hooker long tube headers
4" mufflex system
custom ED Wright chip
eddelbroc intake base and runners and much more
new best ET 13.5 @104.66 on stock heads
no times with new afr heads hoping for 12's on motor
http://www.nav.to/badass355tpi
Old May 7, 2001 | 03:29 PM
theformula's Avatar
Was it just a dyno run or a dyno tune? Try to see what the A/F ratio is and where you need to add/subtract fuel. Makes all the difference.
91 Formula 1LE 1 of 46
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 supercharger(SN93 upgrade), Ford SVO 24#injectors, Crane AFPR,SLP airfoil, ported/polished plenum, March alt. pulley,Crane Gold 1.6rrs,MSD coil,MSD6AL (5200rpm limit),Holley 9mm wires,Ac delco R43ts plugs,custom chip,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old May 7, 2001 | 05:31 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
damn that is really low. id expect to see 320+ at the wheels. What is the grind on the cam? Also those AFR's might be holding you back. Most AFR heads i have seen have really crappy intake to exhaust ratios. You might want to consider some better heads, maybe some Brodix or Darts. Even GMPP aluminum L98 heads have better ratios.
Old May 7, 2001 | 07:11 PM
F22Raptor's Avatar
I've heard that Crane makes some crappy cams for our cars. I've seen the specs on the catalogs and they don't seem very big.
Rick
'88 GTA 350 Full of Leprosy (rust)
Check out my car here:
[url] www.fortunecity.com/silverstone/brabham/42/ [url]
13.39@102.50 MPH
1.90 Sec ----- Best 60FT
104.23 MPH -- Best Trap Speed
AIM HIGH!
Old May 7, 2001 | 07:49 PM
Lounge Lizard 6's Avatar
theformula is right. I went to a dyno tune and did my pulls with a wide band O2 sensor. I was running real rich. I pulled out my Ed Wright chip and installed a new chip that a local guy just burned based off the readings. After 3 pulls, with some adjustments in between, I picked up 15 more HP.
Mike
'90 IROC-Z , 5-speed, ZZ4, G1 Trick Flows
Moderator SEThirdgen
Old May 7, 2001 | 08:38 PM
well last year i ran a best of 13.3 and a consistant 13.5@104.66 on stock heads i thought my new heads would really help me out i was hoping for 12,s
4" mufflex system
MustangBeater20
Oct 29, 2022 09:20 PM
1984HO
Mar 19, 2021 11:59 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Reborn756
Sep 4, 2015 03:42 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
