snapped IAC in throttle body!!!!
Old Nov 22, 2007 | 06:55 PM
poppn's Avatar
Car: '85 Firebird, '74 Nova
Engine: 2.8, 5.7
Transmission: T5, TH350
Axle/Gears: 3.42 open, 3.08 open
Yup. Broke the IAC in the throttle body. Now I need to find that plate that goes on top of the throttle body where the vacuum harness goes, if that is what it's called.
I need serious help as this is my daily driver. What is the name of the plate that the IAC goes into? Where would I be able to get one.
Thanks so much.
Old Nov 22, 2007 | 09:09 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: snapped IAC in throttle body!!!!
its called throttle body iac housing.go to www.tpiparts.net go in catalog ,scroll down to throttlebodies click &scroll down plate is $35.00, later jimmy
Old Nov 22, 2007 | 09:32 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
isn't the IAC plastic?If so,just break the pieces out and get a new IAC valve.If you need that plate,I happen to have a 2.8 from a 88 rs in my driveway.The motor is no good,but that part is.
Old Nov 22, 2007 | 10:53 PM
poppn's Avatar
Engine: 2.8, 5.7
Good news, I got the broken threaded piece of the IAC out of the housing with a chisel and a hammer.
Now I just need to find a new IAC. I was looking at Autozone's website and found this:
http://www.autozone.com/N,15900207/s...eResultSet.htm
I'm assuming the two different part numbers are the threaded and non-threaded versions, but I can't tell as there are no pictures. Hopefully my Autozone will have the threaded one in stock, otherwise I need to order it.
specialized
Jun 18, 2022 09:26 AM
db057
Sep 4, 2015 07:57 AM
mdtoren
Aug 23, 2015 12:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mdtoren
Aug 16, 2015 05:45 PM
