Fuel sending unit
Old May 12, 2001 | 07:00 PM
DG's Avatar
DG
Fuel sending unit
Hi,
I was putting my fuel pump / sending unit back in the tank and brok ehte purple wire connection right where it connects to the sender housing .... this looks liek where the variable reisistor is that will send the fuel level to the car. I tried solder the connector back together but it won't solder. The sender only has 20,000 miles on it and worked fine, I would like to reuse it, a shame to throw away just becasue of a checp connector. Does anyone know how to fix this or if the sender connection can be bought from some supply house ?
Thanks,
Derek
Old May 12, 2001 | 09:37 PM
DG's Avatar
DG
Must use acid core solderto hold to the sender, Thanks DG
<font face="Verdana, Arial" size="2">Originally posted by DG:
Hi,
Thanks,
Derek
</font>
Old May 12, 2001 | 09:50 PM
Guest
Guest
Posts: n/a
Well, I'm glad thats all cleared up....
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Irocohio
Aug 12, 2015 08:03 AM
