What is the Best CAM?
Old May 10, 2001 | 10:15 AM
MY87GTA's Avatar
I have a 350, 5 speed (motor swap) in my 87 GTA. I'm not sure what kind of CAM is in it because the guy i bought it from went to Jail before i could find out. So what CAM would any of you recommend. I'm looking for performance but a daily driven car. I found some in Jegs but i'm not sure about any of them. Thanks
Old May 10, 2001 | 11:11 AM
Bill87GN's Avatar
Need to tell us what you want out of the car (ie. performance goals), also need to tell us what mods are on the car or what you intend to modify. Can't just toss a cam into the car expecting it to run quicker. A slightly larger cam than what you have may do well, but once you start getting into larger cams, you need to look at your intake and heads and see if they can flow enough to feed. Then if you upgrade heads and intake you need to look at fuel delivery and supply. By the time that's all done you probably will need some type of PROm to tie it all together depending on how radical you go. Tell us more about what you have, and where you intend to go, then we can help you out with a cam selection better
-Bill
-=1987 Buick Grand National=-
Almost Jacked Up Like a Mother
*CC 218/218, ported and polished heads (1.77, 1.50), Accufab AFPR, custom DP by Custom Tubes,
Walbro 307 hotwired, Big Mouth cold air intake, 009s, custom PROM and 20psi of fury*
Wanna try me?
-=ICON Motorsports=-
Modertor TPI board
Old May 10, 2001 | 11:59 AM
MY87GTA's Avatar
Ok, i have a 350 TPI, 5 speed, MSD 6al box, 1 3/4 SLP headers, gutted cat, 80 series flowmaster, B&M ripper shifter, Accel 8.8 wires, subframe connectors, 3.73 gears, K&N air filter.
I plan on doing the "free mods", buying an air foil, some sort of cold air induction, underdrive pullies, and a want a power chip but am having a hard time with what to buy. My car is a daily driven car so i need a CAM that idles good. As far as head work done, i have no idea because the guy is in Jail.
Old May 13, 2001 | 07:58 PM
Steve R's Avatar
It's not red with a tan interior, is it?
1980 Camaro, '88 Police 350 engine, Headers, full exhaust, completely redone, my baby!
1988 Iroc-Z L98, MSD 6a, Accel coil, K+N's, Airfoil, Coolant Bypass, Flowmaster, Gears, Late model Bose, I like the 80 better
Old May 13, 2001 | 10:57 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Do you know if its a roller engine or a flat tappet engine? That makes a big difference which cam you can use.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
Old May 14, 2001 | 09:12 AM
MY87GTA's Avatar
No my car is black on black, not sure what kind of motor, i will try and find out
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
