Best and cheapest way to improve my stock 92z
Old May 22, 2001 | 08:06 PM
92heritageZ's Avatar
i have the 92 heritage z with the 5.7 tpi. the only mod on it is a flowmaster muffler. i plan to get k&n airfilters for it too. i need other suggestions for making it run faster. is there a ram air kit for it without getting a different hood?
Old May 23, 2001 | 02:07 AM
silverstreakII's Avatar
Air induction is the best you can come up with? Throttle Body increase, ported and polished heads and runners, new maf sensor,random tech catalytic converter, 3 inch exhaust, smog legal headers, jet chip, lower gears, hotchkis suspension, weight reductions(kinda extreme) B&M megashifter, high stall converter, cam, stroker kit, high pressure fuel pump, higher pressure injectors, the list goes on... so many things, so little money
Old May 23, 2001 | 09:57 AM
formul8!!'s Avatar
Car: 2004 GTO
Cheapest?
-K&N filters
-Drag Radials
-125hp Nitrous Kit
Total: about $1,100
Old May 23, 2001 | 10:11 AM
91-ZZ4-Z28's Avatar
Random Technology used to sell a ramair kit for about a $100 and it helps (they don't have it on the web site anymore but call them and ask)also you can cut out the bottom of your air box or at least remove the baffles this is good for 3-4hp and is free. That and some headers will help the most for the cheapest. All the other stuff is a good idea to but not the maf the 92 is a speed desity system it has no maf. N2o is always cheap but if you have high mi. I would think twice.
1991 Z28 ZZ4 with LPE superram base, SLP runners, LPE 58mm T-body,Random Technology ramair,TES headers,24#svo injectors,and just about every other bolt on that there is. Just got a ZEX nitrous kit!
Old May 23, 2001 | 10:36 AM
91-ZZ4-Z28's Avatar
SLP also has a ram air kit but in my opinion it is a bit on the high side price wise for the power toy get.
Old May 23, 2001 | 08:00 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
If you want to have ram air (inexpensive) goto the tech articles section and do the "Free" ram air. Not too expensive compared to some of those prices you'll see aftermarket, plus some...decent gains.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
Old May 23, 2001 | 09:00 PM
jmon92conv's Avatar
pick up an air foil while you are at it. Get a good one like SLP or something.
Jeremy
WE WILL MISS YOU #3
92 Z conv
5-spd B&M shifter
home-made ram air, air foil, headers, no cat, TB bypass, kevlar pads, slotted rotors, BMR panhard, alston SFC, 3.42's, Edelbrock STB, 350 in the works
Old May 23, 2001 | 09:23 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
vigillante converter and a shift kit any major mods you wont see due to the ecm speed density wont adjust for performance mods without a custom chip.powerchips ed wright will burn you a chip should help out a lot
Orr89RocZ
Apr 25, 2016 08:28 AM
Genopsyde
Oct 7, 2015 08:35 PM
dutch930
Sep 11, 2015 06:58 AM
Out-Cast
Aug 22, 2015 07:49 PM
NWAsonoma
Aug 18, 2015 05:45 PM
