Code 33, wtf?
Old May 23, 2001 | 01:31 PM
gunnman54's Avatar
Code 33, wtf?
My car died on the road the other day and I pulled the trouble codes and got a code 33. I have checked the tps voltage, checked for vacuum leaks, and replaced the maf. But the car still will only start if I hold down the gas and the second I let off it will die. Could the IAC valve or the EGR valve be bad?
Old May 23, 2001 | 04:55 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
i had that problem. set your idle speed higher by turning the screw in the throttle body.
Andrew
Old May 23, 2001 | 06:23 PM
rondubbs's Avatar
<font face="Verdana, Arial" size="2">Originally posted by smokin87iroc:
Andrew
</font>
thats the same as changing your TPS. by moving that screw, the tps is also moving
Old May 23, 2001 | 07:19 PM
IROC KID's Avatar
Look for any loose wires,i had a lose wire under the MAF and when i plugged it in voila!
www.rearman.com/camarokid.htm
If it aint a V-8 that $hit aint fast!,unless its a GN,lol!
305 tpi,700r-4 with shift kit,My mods are minimal,just a bunch of little $hit.Anyone know where to get underdrive pulleys for a v-belt set up?
Old May 23, 2001 | 07:41 PM
AfootVoyager's Avatar
adjusting the idle screw will adjust the tps, true, but will also admit more air, and thus more fuel......
Scott Downs
85 Trans Am
305 tpi/700r4
3.73 w/255/60R15
plain firebird nose(for better engine cooling)
T-Tops, pwr everything
been to about 140mph
Old May 24, 2001 | 08:22 AM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Did you replace the MAF with a used unit, or rebuilt unit? Consider replacing:
MAF Burnoff Relay
Fuel Pump Relay
MAF Power Relay
...about 10/11 bucks each located on the firewall near the brake booster.
Afterwards disconnect battery for about 5 minutes to clear codes and reconnect and check for 33.
What year is your car? 1986 models had a bugged PROM that would trip false code 33's.
Old May 24, 2001 | 02:49 PM
rondubbs's Avatar
alos make sure your connections to the maf and relays are clean, no gunk build up or oxidation on them.
Old May 25, 2001 | 01:38 AM
gunnman54's Avatar
well it looks like the problem was a bad IAC, thanks for the help though.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
