Runner clogged???
Old May 22, 2001 | 01:50 PM
bowtiez's Avatar
Runner clogged???
Had to replace the sensor on the EGR and decided to clean. On each runner is one small port which i assume is air idle bypass. One side alows air thru other is blocked towards intake manifold. Is there any way to clean and open this short of removing intake??
thanks
Bill
Old May 23, 2001 | 09:38 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Nope, you need to remove the intake, take off the belly pan and remove the 4 9/16" allen plugs to get all that gunk out of there.
Old May 25, 2001 | 10:58 AM
Desert86Roc's Avatar
Actually, when my EGR was clogged, I had good luck pouring carb/FI cleaner (I used GM top engine cleaner) down the runner holes (with the plenum off). Clean all the passages in the plenum (spray cleaner through them until clean or soak it in a tank). Worked great.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
bryan623
Sep 19, 2015 10:13 AM
