Car feels down on power occasionally
Old May 23, 2001 | 10:56 AM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
When I first start the car in the morning I'll give it a few minutes to warm up. When I start driving though, the car feels like it's way down on power, almost like it's resisting when I push the accelerator. Once the car gets up to around 150 degrees, this goes away. Still though, there are times that when I really get on it, it feels like it just isn't pulling like it should. The tach climbs like normal but the acceleration is slower than it should be. This is even more noticable when there is a greater strain on the motor like going up a hill or carrying more passengers. I know this will always slow a car down but the lack of power is exceptionally bad with my car when there is a strain on the motor. I havn't been able to figure it out. I've checked the TPS voltage and it's fine. I've also checked the fuel pressure and it only drops about 1-2 psi at around 4000-5000 rpm. I'm not sure what could be causing this so please help me out. Thanks
1991 Z28 - 350 TPI, T56, McLeod street clutch, LT4 pressure plate, Pro 5.0 shifter, ported plenum & runners, AFPR, Holley Annihilator ignition box and wires, Hooker shorty headers w/o AIR, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Kenny Brown STB, Global West steering box brace, Steve Spohn adjustable torque arm and T56 crossmember
Old May 23, 2001 | 01:03 PM
Could it possibly be that the timing is off?
Old May 25, 2001 | 07:32 AM
Come on guys please help me out. Any suggestions at all would be helpful.
Old May 25, 2001 | 12:37 PM
custman87T/A's Avatar
I would check the timing and possibly retard it a couple of deg. maybe the knock sensor detects something.
Old May 25, 2001 | 02:40 PM
Thanks for the reply. I would have never thought of it being the knock sensor. I have a new one in my garage that I bought months ago and just never put in. I'll do that this weekend when I already have the coolant drained to change out the radiator and water pump. I was also planning on checking the timing this weekend also. Anyone else have some suggestions? Again, thanks for the replies.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
novaderrik
Aug 10, 2015 12:44 PM
flash2042
Exterior Parts Wanted
Aug 7, 2015 05:58 PM
