pics of v-belt TPI cars(85-87) engine compartment
Old May 23, 2001 | 08:29 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
My car is all apart and I need some close up pics of the engine compartment for my 1986 Iroc. I am particularly interested in the alternator clocking and the brackets that hold the accesories on. I sort of forgot where a couple go. We are reassembling the alternator tonight(after powder coating). I will not have AC or smog so I will only have 1 main belt and 1 power steering belt. If anyone can help I would appreciate it.
Thank You
Chris
1986 305 TPI
8.0 @88 in the 1/8
**Soon to be 355
Old May 23, 2001 | 01:31 PM
Desert86Roc's Avatar
At the top of my Modifications page, there are some right, left and center pics of my engine...it might help, but I can take other views if you need them. Click on the link below to go to my website.
Mike Metzler (Desert86Roc)[*] Webmaster: SpeedWorldMotorplex.com[*] Click Here For 86 IROC 305 TPI (406 build in progress) Page
ET's @ 1250 ft[*] 14.28 @ 95.461 mph (uncorrected, NOS, no headers)[*] 15.365 @ 86.785 mph (uncorrected, headers, no NOS)
Old May 23, 2001 | 02:12 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Thanks. If you could a couple of the powersteering brackets if you could. Thanks for your help
Chris
Old May 25, 2001 | 10:54 AM
Sorry...I dont have access to my car right now...it's in the shop being re-painted. I should have it back next week if you can wait.
Old May 25, 2001 | 12:04 PM
TunedPort350's Avatar
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
Chris,
I tried to send you some pictures, but your email address listed with your profile (nufnuff@aol.com) doesn't work. Is this your correct email address?
So, I posted them here for you instead:
http://hometown.aol.com/tunedport350/tunedport350.html
If you need more, or these aren't clear to you, let me know and I'll take some more.
[This message has been edited by TunedPort350 (edited May 25, 2001).]
Old May 25, 2001 | 01:17 PM
leirch's Avatar
Check out my webpage in the sig, that should show you EVERYTHING that you need to see/know. The car has pictures of the front end torn down.
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old May 25, 2001 | 03:49 PM
98_1LE's Avatar
I don't know if these will help or not:
I will try to get some of the pulleys/brackets this weekend.
-Chuck
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
Terrell351
Jun 13, 2021 01:13 PM
Wade787b
Sep 29, 2015 01:15 PM
Brcharrelson
Aug 26, 2015 07:47 PM
NBrehm
Aug 25, 2015 11:49 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
