Gas Mileage Superam
Old May 24, 2001 | 09:13 PM
ImportsRsloths's Avatar
Gas Mileage Superam
Hey, I have a few questions concering gas mileage?
1) does headers and a good cat back exhaust give you better gas mileage
2) will adding a super ram give you better mileage
3) super ram + 58 mm Throttle body + intake + runners give you better mileage?
If I understand correctly, if you keep the compression the same, and keep the engine properly tuned. Any mod like aluminum rockers, rollers, etc that just improve the engines effieciency will not only improve the power, but also improve the gas mileage.
What would a 383 stroker with a T56 trans with the super ram, super ram manifold, large runners, 58 mm TB (or would 52 be better for mileage? like a carb) with good heads get?
ANY REPLY IS APPRIECATED!!
IROC-Z :
Jet Black, Tinted Windows, Racing 5 Spokes, Big Block Hood, 91-92 Ground FX, 91-92 Z28 Spoiler, Headlight and Tailight Covers, Lowered. BAD @$$!!
Old May 24, 2001 | 09:27 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
I would think that, exhaust, etc will help, but the stroker would be pushing it... but...then again if you talk to grumpy or glenn they can probably show you cars in the 11's getting 25 mpg with a custom eprom. So i guess the answer would more than likely be anything is possible.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
Old May 25, 2001 | 01:59 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
Yep, I agree with the above answer. More cubes will require more fuel, all other things being equall. Other than that you can gain power + efficency with the right parts. Your driving style/habbits will make a bigger difference than the parts. More than that the "tune" or "calibration" of the PROM or an aftermarket computer will make the biggest difference.
I remember a few years ago, when Car Craft Magazine was running their annual Real Street Eliminator. There was a red third gen with a Super Ram, and I think a 355 CID engine, but not sure. May have been a 383. Anyway, it ran 11s or 12s in the Ľmile and got 33 MPG in the milage test. That was with a feather footed driver and an Accel DFI computer with a tune for fuel miser duty.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
Old May 25, 2001 | 10:39 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
i think that was a 355 engine in the t/a i believe it was blue however but the intaake was a hybrid tunnel ram tpi he also had a special intake setup that ran across the length of the radiator support to each fender.
Old May 25, 2001 | 11:16 PM
Bobalos's Avatar
If you dont do any tuning on it & put some parts on it your milage may suffer or may get a bit better. if you put in a nasty cam, say good buy. if you increase cubes again mileage goes down. if you do both & then tune the car in I would expect that your mileage can get back up to reasonable. heck if you are using the 7730 & you get the highway mode tuned in your mileage could be awesome. just dont stick in that race only cam & think that it is going to be happy. pick your parts right & all will be good.
BW
Bobalos
aka Bob W.
www.r71camaro.homestead.com
r71chevy@earthlink.net
Old May 26, 2001 | 10:05 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Because the Superram retains the EGR, it SHOULD theoretically be able to attain the same fuel economy as TPI on a steady state cruise on the highway. The EGR is a key component in getting good gas mileage and invoking Highway Mode really needs the effects of the EGR to maximize the settings for Highway Mode.
Now, when you put your foot into it, that is a different story. HP requires Air and Fuel. If your mixture is right and you are inhaling more air, you will need more fuel: which is why you are installing the Superram, to get more HP.
Old May 26, 2001 | 01:07 PM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
I get around 25 MPG.With a 406, t56 and 3.91 rearend.Check my web site for my mods.
www.geocities.com/camaro1j/myz28.html
406
accel supper ram
6000 rpm Hyd roller cam
afr heads
spohn torque arm and crossmember
t-56 trans, [wier racing bellhousing and hydrolic throwout bearing]
9" ME rearend 3.91 Gears
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Glowsock
Sep 11, 2015 11:09 PM
