Exhaust crossovers and Dart heads
Old May 22, 2001 | 11:39 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
I got a set of Dart Iron eagles going on here pretty soon and somebody mentioned something about exhaust crossovers or something in the heads. WTF is that? is this an EGR thing? I have no idea if the Darts have them or even what the crossovers do. Help please Can i modify my emmisions system to bypass the crossovers or do i not need to even worry about it? Thanks for the help everyone.
1988 IROC-Z L98
License Plate: STG KLR 1
Engine Mods:
Edlebrock TES Headers, Hypertech Chip, Flowmaster Muffler, Intake Airfoil, Removed MAF Screens, MSD-6A, MSD Blaster 2 GM Coil, bored .030 over, Other minor mods
Suspension Mods:
Lakewood Traction Action Lift Bars, Hal Rear Shocks
Trans Mods:
2,500 stall converter, Redline clutches,Heavy Duty Steels, Trans-Go reprograming kit , Heavy Duty 2-4 band, Corvette Servo, B&M Mega Shifter w/ Carbon Fiber Handle (looks sweet in a black car!)
ET: 13.833@99.30
"If you can put it on your car, its fair" Quote By Guido
Foundering Member of the Illinois Overkill Crew (IOC)
www.mfba.org
[This message has been edited by 88blkiroc (edited May 22, 2001).]
Old May 23, 2001 | 10:22 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
ttt
Old May 24, 2001 | 10:58 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
anyone???
Old May 25, 2001 | 01:35 AM
93ND500's Avatar
Yes, it is an EGR related item. It is also used to heat the manifold on older cars. Dart Iron Eagles DO NOT have provisions for this.
You can bypass it. Vortec heads do not have crossovers either, they use an externally plumbed system to route the EGR gases back to the manifold. You would need to use the same kind of setup if you are planning on using the Darts.
Old May 25, 2001 | 10:03 AM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
I believe the v6's use a similar setup to what 93ND500 is describing.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
Old May 25, 2001 | 10:07 AM
89ProchargedROC's Avatar
you silly silly man. why dont you ever ask me?
just take off your emissions crap and block off the egr and put a intake gasket with the little metal thingie in the middle to block off the EGR also.
problem solved.
my EGR has been disable for a while now and i hardly ever get a SES light, just when the computer tries to open the valve is when it comes on, then when it wants it closed it shuts off. haven't had the light in about a year and when i did it was only for like 10 minutes
Old May 25, 2001 | 05:31 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
Jimmy, you are my thirdgen god
Old May 25, 2001 | 06:00 PM
90 Z28SS's Avatar
Emissions , whats that
The un-smog third gen club
I you take all that **** off Kyle call me , I have the right belt #'s you'll need to run . I say #'s cuz with no pump , you can bypass the power steering at the track ...gotta love 2 tenths for the cost of a belt
Old May 25, 2001 | 09:12 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
No power steering...damn id need skinnies, ever try to turn P245's without power steering??? Ill give ya a call when i do all this crap man. Me and jimmy were talking about taking of the AIR pump and the A/C. We aare trying to figure out how to gte rid of all the hoses and crap. every 3rd gen i have seen without the Air pump and AC still have that octopus above the valve cover. I dont want that crap hanging there. U know how to get rid of that crap?? Thanks man.
Old May 26, 2001 | 12:48 AM
90 Z28SS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 88blkiroc:
No power steering...damn id need skinnies, ever try to turn P245's without power steering??? </font>
Wussy boy , its not that hard , your just getting around the pits like that .
That thingy above the valve cover is not emissions stuff , it has to do with the heater , Coolant runs thru those hoses and that valve thing . You could omit the valve and re-route the hoses . Without the valve coolant would costantly flow thru the heater core , I would assume . I will be doing this to mine while the car is down , among many other things , can you say re-wire time . Time to clean house
When your ready to desmog yourself , just call . I could come up and help if it were on a Sat. or something , just have alot a Mountain Dew . L8
[This message has been edited by 90 Z28SS (edited May 25, 2001).]
Old May 26, 2001 | 02:27 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
Cool man. Hey whats going on with your car now?? U selling or what?
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
hayesaw0210
Aug 23, 2015 11:15 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
drathaar907
Aug 6, 2015 04:20 PM
