383 Cam selection?
Old May 21, 2001 | 08:15 AM
RGS1260's Avatar
383 Cam selection?
383 SportsmanIIs Superram DFI computer
Cam choices are Comp Cams Xtreme Marine:
12-236-3 462/477 218/224 @.050 112 1300to5500
or
12-240-4 480/489 226/236@.050 112 1600to5800
52 or 58 MM TB
What size injectors?
OR
12-418-8 503/510 224/230@112 1800to 5800
[This message has been edited by RGS1260 (edited May 25, 2001).]
Old May 21, 2001 | 04:13 PM
Dan87IROC-Z's Avatar
I would go with the second one assuming you can feed it well enough with the proper intake and heads. That looks more like a cam for a motor with 195cc heads and high flow intake like Super Ram or MiniRam.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Old May 24, 2001 | 02:59 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
I'd recommend cam # 1: Its more similar in profile to the LPE 219 cam that was designed for the superram. You would be quite torquey. I also highly suggest you spend some extra $ and convert over to a roller cam equivilant for added lift.
I'd try the 52mm and 24 lb injectors first, then step up to 58mm and 30 lb. only if the dyno shows you approaching 85% duty cycle at the top end.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff., Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
Best of 14.039 at 100.82 MPH in Stanton, MI
New! 275-40-ZR17 tires on ROH ZS 17 x 9.5's
Old May 24, 2001 | 03:38 PM
jayg's Avatar
Car: 1992 Formula 350
Why not use the Superram specific cam from Lingenfelter?
Old May 24, 2001 | 09:38 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Get those Darts ported and that intake and base also.
Old May 26, 2001 | 08:40 PM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
get a cam with the range of at least
2500-6000. That is the cam I have.It has alot of power but,when I hit 3000 RPM my car takes off like I hit the no2 button.
part# 119831
grind # hr-284-2s-12 IG
222.0-230.0 duration
509-528 lift
2500-6000 RPM
LOOK AT MY WEB SITE FOR THE REST OF MY MODS.
www.geocities.com/camaro1j/myz28.html
406
accel supper ram
6000 rpm Hyd roller cam
afr heads
spohn torque arm and crossmember
t-56 trans, [wier racing bellhousing and hydrolic throwout bearing]
9" ME rearend 3.91 Gears
Jorlain
Oct 8, 2015 01:57 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
masonta
Sep 1, 2015 06:40 PM
