Do I need to change valve springs with rockers...
Old May 27, 2001 | 11:34 PM
scanman717's Avatar
Car: 92 Z/28 Convertible
Engine: LB9
Transmission: Mad Dog Auto 700R4
I am debating putting better rockers in my car. I have an LB9. If I went with 1.6's do I need to change anything else, like pushrods and springs???
92 Camaro Z28 Convertible
3" Flowmaster
Ported Plenum
Old May 28, 2001 | 12:13 AM
87iroczmd's Avatar
you should get self aligning rockers or else you need to machine the heads and put push rod guide plates in, new valve springs would be a good idea also
Old May 28, 2001 | 11:13 AM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
If thats all your doing is changing 1.5 to 1.6 rocker arms I wouldn't worry about it. If you were going to a bigger then yes. get a spring checker just to make sure they are still in good shape.
www.geocities.com/camaro1j/myz28.html
406
accel supper ram
6000 rpm Hyd roller cam
afr heads
spohn torque arm and crossmember
t-56 trans, [wier racing bellhousing and hydrolic throwout bearing]
9" ME rearend 3.91 Gears
Old May 28, 2001 | 11:37 AM
Vader's Avatar
Scan,
I went with 1.6:1 rockers on my LB9 with the standard valve springs. The lift and ramp of the "LA" (LameAss) cam is so pitiful that a good ball point pen spring would probably control the valve adequately. Don't lose any sleep over it...
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
crazynights
Aug 21, 2015 06:53 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
