Are the S/R 305 Torquer better than stock TPI heads?
Old May 28, 2001 | 07:01 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I read this article in recent magazine that by switching heads on a 305 TPI (mainly stock) they gained almost 50 hp.
1. Did anybody feel the difference after the head swap?
2. What is so good about these heads?
3. Would you reccommend these heads or not to bother?
Then I guess the stock heads must be a piece of S_ _T. or am i wrong?
Thanks.
89Iroc, 305 TPI, WC T5, 3.08 Posi, Flowtech Headers 1 1/2, Hooker Y-Pipe 2 1/2, 3 inch over the axle, Flowmaster 80, No Cat, Aluminium Driveshaft, Ported Plenum, Air Foil, MAF Screens/Fins removed, K&N, Gutted Air Boxes, AFPR @45 psi, Ram Air, Throttle Body By-pass, Bumped Timing @12, Bosch +4, MSD 8mm wires, HP Rotor, Cap and Fuel Filter, Sensi Trac rear Shocks.
Old May 28, 2001 | 07:02 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
One more thing
Are they a swirl type heads or not?
Old May 28, 2001 | 10:32 AM
vortech305's Avatar
Well i can tell u this, my 88' ported and polished corvette alluminum L98 heads outflow the world heads, and i spent less money.
Old May 28, 2001 | 12:28 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
http://everythingnova.homestead.com/headflow1.html
See for yourself.
Old May 28, 2001 | 08:14 PM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
89GTA which ones aply to cast L98??
white/gold GTA ,leather 5.7TPI 700r4 3:27posi twin cats,3"catback,aluminum d.shaft ported plennum,afpr,8mmwires,k&Nand all other "free" mods, performance resource chip,SLP cold air intake.
Old May 28, 2001 | 08:19 PM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
89GTA which ones aply to cast L98?? and r 350 Sr torkers worth the $
Old May 28, 2001 | 08:23 PM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
oops also were is everyone gettin vette heads cheaper that SR Torker??? what price and r they new? and assembled
Old May 28, 2001 | 09:03 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
The L98 heads are identified in that list.
There are 2 types of S/R torquers, a 305 version with 1.94-1.50 valves and a 'regular' version with 2.02-1.60 valves.
If I were buying a set, I'd get them pocket ported at the minimum and make sure I ran as much compression as possible.
I would look for some used heads if I were you. I think SPDC sells ZZ4 Aluminum heads new for real cheap. With $600 of port work, they will flow good.
There is also nothing wrong with getting your stockers ported.
Old May 28, 2001 | 09:50 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
be careful on valve size, you dont want to run a 350 head on a 305 and have the valves whacking the deck.
[This message has been edited by 88blkiroc (edited May 28, 2001).]
Old May 29, 2001 | 05:22 AM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
are the zz4 heads emmisions legal? and r they direct bolt ons to tpi?
Old May 29, 2001 | 11:11 AM
vortech305's Avatar
I got my vette heads for $350.00 from a guy who rebuild it, looked brand new, anyway, left the stock valves on, did a port and polish job, by new jersey performance,$300.00. $650.00 all together not bad.
Old May 29, 2001 | 03:38 PM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
sdpc got vette heads assembled for 800$ and i am planning on porting them my self .i got it narrowed down to SR torkers or ported vette heads?
Old May 29, 2001 | 04:56 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
The Vette heads won't have the EGR on them like the cast iron L98's, so if you need to pass a visual and functional test, there may be an issue.
Old May 30, 2001 | 12:10 AM
Glen's Avatar
Engine: chevy 383
Transmission: tci streetfighter auto
Axle/Gears: 3.70 moser 9"
Eddie, you still have the old EGR issue to deal with. Check out that website again with all of the heads listed. I'm telling you the SR Torquers may not be the hottest but they are solid performers for the $800 that you want to spend on this. I am very happy with mine. I only wish that I had some quarter mile times to back up the seat of the pants performance I am experiencing with this engine. Cast Iron doesn't have the corrosion or warping problems of aluminum. Looking at the tables, the SR's have excellent exhaust to intake ratios and are better than most stock iron heads excluding the vortec which we can't use anyway. Bolt them on, easy, emissions legal upgrade. End of story.
Red '85 MPFI V-6 T-5 Sport Coupe (bought new),now an IROC in sheeps clothing.
Rebuilt and installed '88 IROC L-98 TPI,700-R4,3.27 posi/disk rear,instrumentation, steering gear, and all suspension parts (even the wonder bar)
Mods:
IROC wheels, Hi-perf. rebuild on 700-R4,TCI sizzler torque conv.,B&M megashifter, L-98 .030 over,balanced,decked,blueprinted, SR Torquers, KB pistons,9.1:1 CR, port matched stock TPI, comp cams .450/480 206/210 cam, all free mods, subframe connectors, Edelbrock TES/jet hot coated, CATCO cat, Hooker catback, MSD 6A, airfoil, AFPR, K&Ns, polygraphite bushings all around, 1989 IROC memcal in summer, ARAP memcal in winter.
Old May 30, 2001 | 05:36 AM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
damn! i thought vette heds were emmision legal ok back to the drawing board....
Old May 30, 2001 | 11:10 AM
Steve89GTA's Avatar
The vette's heads can be made Emissions legal by adding an external EGR valve just like they were on the vette. When I rebuild my bottom end, the heads will be the S/R Word products that's for sure...mild port job and bolt em up.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Grant2k
Jul 10, 2018 04:01 PM
st.evel07
Aug 13, 2015 06:15 PM
marcusaw
Aug 10, 2015 08:13 AM
drathaar907
Aug 6, 2015 04:20 PM
