tps reads 3.36 @ wot, is it bad
Old May 31, 2001 | 11:59 AM
87iroczmd's Avatar
my tps reads .60 at idle, but 3.36 @ wot, does this mean the tps is bad, or can i adjust it at wot without changing idle
Old May 31, 2001 | 12:37 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
It should be about 4.5 @ WOT, and yes, you can adjust it. I dunno about having to adjust your idle afterwards, tho...
KAM
Old May 31, 2001 | 01:55 PM
leirch's Avatar
Actually, it depends. How do you know its at the 3.xx voltage at WOT? Scanner? Voltmeter?
If you have diacom or some scanner, see what the %of throttle is set at when it is at "WOT". If it is at 100% you should be fine.
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old May 31, 2001 | 02:01 PM
87iroczmd's Avatar
i used a voltmeter, if i adjust the tps @wot will the voltage at idle be affected
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
