305 & the 350 EGR
Old Dec 13, 2007 | 10:15 PM
wildchild's Avatar
305 & the 350 EGR
I have an 87 gm, it came with a 305FI, I put a 350 in it a few years back and used the my old 305 intake on the new 350, I believe my EGR is bad, I am being told that the 305 & the 350 EGR are not the same for the two motors, They look the same, take the same gasket on both motors, the 305 EGR is $105 and the 350 EGR is $75, I don't see any difference in the way they look, can any one tell me if there is any difference besides the price,
I am also being told to just block it off, how would that affect the computer and or other sensors?
Thanks for the help...
_________________
Old Dec 14, 2007 | 07:41 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: 305 & the 350 EGR
The difference is most likely the size of the orifice inside to meter how much exhaust goes back to the intake. Buy the cheaper one if you are using EGR.
I don't use it so I would block it off. You may need it if you are trying to pass emissions. It doesn't affect the computer on an 87 as long as the EGR vacuum actuator valve is plugged in so that the computer thinks it is turning it on and off.
Old Dec 14, 2007 | 02:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
I thought the '87 TPI had the EGR thermocouple sensor in it. I could be wrong, but the one I had (and never installed) had it.
If you don't run the EGR, it would be best to program it out of the PROM. May also need to adjust timing tables without it.
I don't know of any problem using the 350 EGR valve. Perhaps this would be better on the TPI forum rather than Engine Swap.
Old Dec 14, 2007 | 08:27 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
I think it sounds more like TBI, but maybe not...
A quick parts price search confirms TBI for the two prices he quoted for EGR valves up top...
Old Dec 14, 2007 | 11:31 PM
five7kid's Avatar
TBI was introduced in 1988.
Old Dec 15, 2007 | 11:45 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
There are 2 type of EGR valves positive, or negative back pressure.
part number should start with a P, or N.
Old Dec 15, 2007 | 01:41 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
For f-bodys, yes, but trucks were 87. I was thinking truck engine....
Sorry about that!
Old Dec 15, 2007 | 04:36 PM
wildchild's Avatar
it is a truck motor, I didn't know that would make a difference about the EGR sorry about that, ya learn some thing new every day, Thanks for all the help with this guys.
Jake_92RS
Jan 28, 2020 10:37 PM
Out-Cast
Aug 17, 2015 10:57 AM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
