just got zz9 what to do with heads
I just got a zz9 cam and was wondering what to do with my vette heads off of a 89 at this point they are stock so any suggestions would be greatly appreciated
Car: 1992 Z28
Engine: 355
Buy matching valve springs and have the spring seats machined to accept them.Also........
1. 3 or 5 angle valve job (cheap)
2. Have them decked to a "true" 58cc (cheap)
3. Pocket port them (pricey)
92Z28
89GTA
92Z28
89GTA
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
tpis sells drop in springs no machining required for the l98's bowl work helps those heads a lot as well as the valve job that was mentioned you send them to be extrude honed while you're at it
<font face="Verdana, Arial" size="2">Originally posted by vinroc:
I just got a zz9 cam and was wondering what to do with my vette heads off of a 89 at this point they are stock so any suggestions would be greatly appreciated</font>
www.cncheads.com . These guys are awesome. I live just a few miles from them. Most magazines located down here building engines use them. They are a little expensive though but worth it.
Jeff
Jeff
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
If you are in NY, call Cartek and have them port them for you. They know TPI stuff.
http://www.cartek.net
Port work should be around $600-$1000 depending on how much air you want.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
