no spark
Old Jun 3, 2001 | 07:32 PM
nate88iroc's Avatar
no spark
I have a 350 TPI. I have no spark at the wires or coil. I have changed the distributer, ign module, coil, pick-up coil, msd 6al, ESC module, have ten volts on the pink and white wires at the distributer. I just tested the msd and the coil on a buddies car. I also just had the ign module tested again and it is good. Any suggestions would be appreicated.
nate
Old Jun 3, 2001 | 08:15 PM
CWIROC's Avatar
have you plugged into the ecm?
Old Jun 3, 2001 | 08:31 PM
nate88iroc's Avatar
The ECM is not putting out any codes. The ECM should not control anything until the engine is over 400 or 600 RPM's.
Old Jun 4, 2001 | 08:37 AM
nate88iroc's Avatar
Anyone else have any ideas.
Old Jun 4, 2001 | 11:54 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Do you have voltage at the coil?
Old Jan 31, 2009 | 10:10 AM
quickbrad's Avatar
Car: 86 IROC
Engine: 355 TPI
Transmission: JUNK
Re: no spark
Why doesnt anyone finish these threads with results. I am having the same problem and have found like 10 threads but none have the solution, its like they fix the problem and just forget about the help that they got here....Whats Up!@#@$%$^
Old Jan 31, 2009 | 10:21 AM
64deux's Avatar
Car: GM WHAT ELSE IS THERE
Engine: 327 bottom tpi top
Transmission: 700r
Re: no spark
ignition switch?
Old Jan 31, 2009 | 12:22 PM
Russ-So Cal's Avatar
Re: no spark
It is frustrating when these ingrates don't come back and give us results, but I suppose it is human nature to be selfish. In your case "I'm having the same problem" doesn't really help very much. If you go to a thread and it doesn't help because no one posted a resolution, instead of resurrecting an old thread, start a new thread with a description of your problem and all of the symptoms you know of. These cars are complicated enough electrically that there are often dozens of possible problems that will appear to have exactly the same symptoms. Wildly guessing and changing various components may eventually fix it, but it is far and away the most expensive method of "trouble shooting".
Old Jan 31, 2009 | 12:26 PM
Chevhead89's Avatar
Re: no spark
if u tested that module at discount auto i woudnt trust it. they tested 2 modules for me that they said was good and neither were! but shouldnt there be more then 10 volts?
Old Jan 31, 2009 | 12:38 PM
Re: no spark
This guy NEEDS to start a new thread. The original post was done on June 4 2001. All of the answers until you get to quickbrad were ancient history. Quickbrad jumped into an old, obsolete thread and took it up again with a complaint that no one gave an outcome. At this point as near as I can tell nothing has been tested, or replaced, all we have is guesses about his problem or guesses of more parts to buy to see if it will fix.
Old Jan 31, 2009 | 01:04 PM
Chevhead89's Avatar
Re: no spark
Ooo ok. gues ill have to pay attention to that.
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
