Where are your supercoils mounted?
Old Jun 3, 2001 | 12:35 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
I have an Accel supercoil and I am curious to where you have mounted them. A pic would be nice or you could just explain where it is as well. I am not sure where to put mine. I have seen one pic of it mounted to the strut tower but I am not sure if that is where everyone has put it. Any help would be greatly appreciated.
Old Jun 3, 2001 | 03:52 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I don't have a pic but mine is mounted on the firewall between the wiper motor and brake booster.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
Old Jun 3, 2001 | 09:48 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I made a bracket that I was able to mount the Supercoil. The bracket looks like a little "box" about 1/2"-3/4" high that allowed me to put bolts through it, into the Supercoil itself. The bottom of the bracket was extended on the "back side" another 1" where I put holes that allowed me to mount it in the stock location. Looks like it always belonged there, and keeps that coil lead from getting too long.
Old Jun 3, 2001 | 03:57 PM
demonspeed's Avatar
Car: 91 1LE
Engine: LB9
Transmission: MM5
Axle/Gears: GU6
Mine is on the firewall near the master cylinder. It was on there before I bought the car. I don't know if you can tell by the pic, but here it is anyway https://www.thirdgen.org/rides/ridei...EnginePass.jpg
-Steve
89 IROC 5.7
FOR SALE
Click for the ad
Accel ignition, K&N, Edelbrock TES headers/y-pipe, Flowmaster American Thunder exhaust, gutted cat, 91/92 Wheels
Old Jun 3, 2001 | 04:31 PM
Panthro's Avatar
Car: '89 Formula, Black w/ gray interior
Engine: LB9, 230 HP, 305 ci, TPI
Transmission: 5 sp manual
Axle/Gears: Borg Warner 3.45 limited slip
Like Glenn91L98GTA, I used a piece of scrap 1/4" aluminum plating I found at a ship yard while I was in the Navy and cut it down to mount the coil. I mounted the coil horizonitaly on the aluminum, offset towards the ac condenser, leaving enough metal on the engine side to drill two holes through the plate and mount it to the orginal coil bracket.
Pat McGrath '89 Formula LB9, T-5
Old Jun 3, 2001 | 06:43 PM
trickfbody's Avatar
If you dont have air, check out
http://www.trickfbody.com
Old Jun 3, 2001 | 08:51 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Thanks for the replys guys. Trick I would love to be able to do that but i do have my ac stuff so that wont work. Glen and Panthro is it that dificult to do it. Could there be any way that you could get a pic if not thats cool I will see if I have you guys figured out. So all it is is a piece of metal that is about 1/4" thick and how wide? about 2" or the width of the super coil. and how long exactly? 3 maybe 4" long? I havent looked that closely on what type of room is there so I will take a look at it when I get the chance. Thanks again any other help would be great.
Old Jun 4, 2001 | 01:33 PM
Steve89GTA's Avatar
I used to have mine mounted forward of the master cylinder until that POS screwed up on me and left me stranded out in cottage country. Replaced with stock coil and have never looked back.
Old Jun 4, 2001 | 07:24 PM
Panthro's Avatar
I'm going to be replacing an injector this weekend and I will probably need to take it off anyway. I'll take some measurements and do up something in paint and e-mail it to you.
Old Jun 4, 2001 | 09:40 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
That would be awsome if you could do that. I would owe you one for that. Just let me know when you are done with it.
Old Jun 5, 2001 | 07:07 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Mine is on the firewall, above the tranny dipstick.
Bob '89 Ram Air Formula 350
And until that time when death won't wait, let each man rage against his fate. (O'neill)
My car's homepage
Rider's Ride
Old Jun 5, 2001 | 08:26 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
RCR-
I thought you posted a pic off my website! That looks exactly like mine. It works pretty decent there I think. Later
'91 GTA:
www.fbody.com/members/91WS6GTA
Old Jun 5, 2001 | 11:58 PM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
i also have mine between the whinshild wiper motor and the break bouster
you can see it on my page at:
http://darcom.home.texas.net/
388 SuperRam, DFI, Vortech R trim ,N.O.S.,alki injection,
Dart sportmansII heads,50 pound injectors, Headman full headers
duel 3' exhaust,and Flowmasters, Ford nine inch with 370's
Ronal rims with Nitto drad raidals.
Old Jun 6, 2001 | 05:56 AM
Gary's Avatar
I mounted mine in the stock location by using two thick metal L shaped brackets I bought from my local hardware store. I drilled the necessary holes to mount the coil, then the L shape of the bracket screwed into the stock mounting holes, looks great and no drilling of holes in the firewall.
92projectcamaro
Sep 12, 2015 12:33 AM
ynk1121
Sep 12, 2015 12:27 AM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
