What PROM for 350 TPI 5 speed?
Old Jun 5, 2001 | 11:55 PM
trickfbody's Avatar
Would appreciate suggestions on what PROM to use for a mildly modified 350 TPI, ZZ3 cam,
5 speed with a 9 bolt 3.27 posi rear. Just finished building setup and used GM stock 305 5 speed prom for expediance. Runs good and strong enough for break in but want to max performance at a reasonable price(whatever that means). I am not quite ready to go the "smoke your own" route yet.
Old Jun 6, 2001 | 01:54 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I used the stock 305 5-speed chip in my 350 engine with ZZ4 cam and ZZ4 heads. There really isnt a chip you can use unless you go the custom route. As long as your car runs fine on the 305 chip, keep it until you get your own prom-burning equipment, or you can find a friend to make you a chip.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jun 6, 2001 | 08:29 AM
blak92!'s Avatar
I called FIS in texas and told them I needed a stock chip for a 350, but have a 5 speed. The guy said no problem, $75 shipped. I also had the VATS removed.
http://www.fuelinjection.com/
Fuel Injection Specialties, 11051 Wye St., San Antonio, TX 78217, Phone: 210.654.0774, Fax: 210.654.0775
Hybrid Black 5.7L 5 Speed
'95 Competition Yellow Corvette Coupe ZF6
[This message has been edited by blak92! (edited June 06, 2001).]
Old Jun 6, 2001 | 07:47 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I would go get a chip for a 350 just like the post above mine. I bought a hypertech chip and paid too much.
1991 Firebird
350 L98 (was a 305 TBI)
T-5 transmission
Edelbrock TES and cat back
Accel manifold
NOS
subframes
jegster torque arm
MSD Digital 6
AFPR
Lakewood lcas
Hurst linelock
SLP cam (206 212 .480 .486)
relocated battery
cold air
Hypertech chip
centerforce clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
a/f gauge
autopower rollbar
14.0 at 100 NA before heads
Juice and AFRs??......TBD
New g-tech time without juice 13.46 at 108.8
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
