Engine won't fire up...
Old Jun 6, 2001 | 11:54 PM
B L A D E's Avatar
I am getting spark, and pressure to the rails. Just changed the fuel filter... wasnt the problem. The ECM threw a code 43 while I was driving it... then started one last time, won't start now. When fuel is sprayed into the plenum, the thing starts up, idles for asec, and dies. I really need to figure this out...please help.
Tris
PS It sure as hell isnt my fuel pump.... I have great pressure, and you hear it loud and clear.
"We are being good - no drunk drinking..."-Red
"Your village called. They're missing an idiot." - Bumper Sticker at Pep Boys
Old Jun 7, 2001 | 12:10 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
You obviously have a fuel delivery problem. If you are getting good fuel pressure to the rails than the problem must lie in the injectors or the injector driver circuits. Get a noid light and see if the computer is sending injector pulses to the injectors. You can also listen to them and/or put a finger on one while the engine is being turned over and you should be able to hear and feel them opening and slaming shut (a ticking sound can be heard if they are opening and closing and you can actually feel the pintle of the injector nozzle slaming shut if you put your finger on there). You can also perform a resistance check on the injectors (blade to blade on the injector with an ohmmeter) but this is often not all that useful unless the injectors are hot. My guess at this point, and it is ONLY a guess, you have lost injector pulse from the ECM. This is either becuase of a blown Injector fuse or a toasted ECM (fried injector quad-driver circuits). That is only a guess so I don't want anybody attacking me - else I will be forced to defend myself... lol. Good luck....
A few ideas.....
1987 GTA L98 MD8 GH3
355 '97 Vortec 4-bolt block, TRW(suck) forged pistons 10:1 CR, TFS 23*, LT4 Hot Cam, Ported plenum and intake, SLP Siam Runners, Edelbrock TES, gutted Cat, Flowmaster, Home-made cold air system w/ K+N cone and AFPR, TB bypass, AirFoil, !AIR, !A/C, !EVAP, 2300 stall.
"Stop Lights timed for 35Mph are also timed for 140Mph"
Old Jun 7, 2001 | 11:46 AM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
It's also possible that the reference pulses aren't getting to the ECM. Below 400 RPM or so the ignition module in the distributor controls spark. When cranking the engine you typically don't get above that so the ECM won't ever take control.
See if you can get a scan tool on the car and watch if the ECM is reading any RPM while you crank it.
I had a similar problem at one time that ended up being a wire that was broken in the distributor harness. New pigtail fixed it right up.
Check all of your grounds too.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
justin57
Aug 20, 2015 07:05 PM
TheExaminer
Aug 19, 2015 10:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
