Throttle Body Differences
The accelerator cable thingie on my '88 TPI throttle body is hanging up a little. When I let off the gas, it doesn't settle down all the way at idle unless I tap the gas real quick. I've traced the problem to the throttle body. Is there any difference between this one and the one I have with my spare TPI setup from an '86 305 Camaro?
1980 Camaro, '88 Police 350 engine, Headers, full exhaust, completely redone, my baby!
1988 Iroc-Z L98, MSD 6a, Accel coil, K+N's, Airfoil, Coolant Bypass, Flowmaster, Gears, Late model Bose, I like the 80 better
<font face="Verdana, Arial" size="2">Originally posted by Steve R:
</font>
</font>
it finally just quit though,
don't know what i did
Car: 89 Iroc
Engine: 305TPI
IIRC there is a difference between those. In 88 they changed the throttle body in the TPI. So the 86 would not fit in the 88 but if someone that knows better than I hopefully they will correct me.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
85-88 use the same throttle body, so yes your 86 TB is the same as your 88 TB. 89-92 is the other style of TB.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
Steve, if you hook your foot under the gas pedal and pull it towards you, does it go back down to the right idle? You may just need to lubricate the accelerator cable. I just used a bit of motor oil and it seemed to help.
Alex
Alex
No, if I hook my foot under the pedal, it doesn't do it. But I should probably do that anyway. How do I go about lubricating the cable?
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
just put your spare TB in and see if that fix's your problem
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I had this problem (ONCE) I forgot to put the plastic cover up properly under the dash, there is a slot where the accelerator pedal is. I caught on the end of the plastic and it would not release. I re-adjusted the plastic cover and all is well now.
87 Formula 5.1 converted to TPI Yellow/Black
SLP cam, headers, cat-back exhaust
Ported & polished TPI intake
Gil Younger (no yo-yo) Shift Kit
Aluminum Driveshaft
3.73 Posi gear
Baer 12" brakes 4 wheels
Hotchiss strut tower brace
South side machine frame connecters
Custom reinforced control arms and pan hard bar.
Custom Leather interior
87 Formula TPI (5 Speed) Yellow/Gray STOCK
83 Camaro (Parts)
83 T/A (parts)
www.3rdgenformula.com
Aluminum Driveshaft
3.73 Posi gear
83 Camaro (Parts)
83 T/A (parts)
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
mdtoren
Aug 16, 2015 05:45 PM
