Argh!! fns will not turn on...
Old Jun 8, 2001 | 06:07 PM
ScreaminDeamin85Z's Avatar
i have replaced the fan switch and both relays for the fans and they still wont turnon. the car doesnt overheat until im in traffic, which is un-avoidable here in houston. anyone? and yes the fuse in the fuse box is ok.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC-Jamex Springs...and thats just about it till summer!
Soon- 6 speed, Pro 5.0 shifter and 4.10's
http://users.argolink.net/bvana
http://ScreaminDeamin.cz28.com
Old Jun 8, 2001 | 06:16 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
relax such hostility.DO YOU NEED A HUG OR SOMETHING?first try running the fans to the battery verify that they do work in my old camaro you could hear the fan wining but the blades didn't turn so do that first.if they check out its a ground problem somewhere in the harness follow the two wires from the connection on the fan through the loom (p.i.t.a but only way)make sure nothing is melted or dry rotted.another way is you know your relay works because its new right from the relay to the fan follow the harness again a p.i.t.a move the harness around a little.a last resort which happened on my car the ground wire for the connector to the relay behind the passenger side headlight came loose it's a weahter pack type connector try pushing the wires up into the relay watch your fingers though.
87 trans am 350 L98 aluminum heads,LT4 hot cam,slp runners,headers,y-pipe,edelbrock base,hi flo cat,air foil,ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt,ads strip chip,relocated iat sensor,hollowed maf
14.10@97mph w/2.01 60' 4SALE anyone want her?
Old Jun 8, 2001 | 06:33 PM
ok i hooked up a fan directly to the battery and it turned on for a sec but then turned backed off. i am going to run through the harnesss and check things out.
Brandon
Old Jun 8, 2001 | 08:22 PM
ahhhhh the problem was that the guy who owned the car before me must have thought he would be *smart* and re-wire the fans. talked about all cut up! i have no idea why he would have done this because the minute i re-connected the wires to there *original* locations...hmm everything magically worked. sad thing is he did the same thing to my harness for the stereo, except i have allready fixed that.
Brandon
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
