What needs to be removed to replace water pump?
Old Dec 27, 2007 | 11:54 AM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I think my water pump is taking a leak on my 305 TPI so I'm going to replace it this weekend. I've done the water pump on a 2.8L, but not on a 305. What needs to all come off to get to it so I am not wasting my time removing extra parts? Thanks!
Dave
Old Dec 27, 2007 | 02:50 PM
Damon's Avatar
Re: What needs to be removed to replace water pump?
With the serpentine setup I don't think anything does other than taking the belt & pulley off and removing the 4 bolts that hold the pump to the front of the motor. Actually much easier than earlier V-belt setups that attached various accessory brackets to the water pump here and there.
Old Dec 27, 2007 | 02:57 PM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
When I changed my water pump on my LO3, all I did was remove the belt, take off the pulley, and unbolt the water pump. It was very simple
Old Dec 27, 2007 | 09:55 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
According to chiltons, take off the belt, disconnect the hoses, and unbolt.
Old Dec 27, 2007 | 10:22 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
That is pretty much it. The worst part is actually cleaning off the old gaskets. It is probably the easiest pump I have ever installed.
Old Jan 3, 2008 | 03:15 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
cleaning the old gasket is a pain in the butt.
You can get it pretty good from under the car.....but you get dripped on.
Old Jan 3, 2008 | 03:36 PM
Car: 89 GTA
Axle/Gears: 4.10
I got it changed out no problem, thanks. I have an 87 with v-belts so I had to remove alot of stuff to get the pump out but nothing rediculous.
Old Jan 3, 2008 | 08:20 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
wow u need to invest in a good handeled scraper and some sandpaper.
or the more a 90* die grinder with the 3m phenolic grinding disks ( i realy don't know what i'd do without these, they are simply amazing).
Old Jan 5, 2008 | 02:45 PM
Pat Hall's Avatar
Hell yeah, a right angle die grinder and a 3m disk is the only way to do it! Takes all of a few seconds to have a perfectly clean gasket mounting surface.
Old Jan 5, 2008 | 08:25 PM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
well that is a lot better idea then my box cutter blade in a pair of vise grips method that i have been using
Old Jan 6, 2008 | 01:15 AM
Car: 1991 Camaro RS
Engine: L98 350 TPI
I used a flat blade screw driver...
Old Jan 6, 2008 | 01:23 AM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
i just insted my water pump afew months ago.
i would loosen the bolts on the pully before taking the pump off. its so hard to get the bolt to come off once the pump it off i had the hardest time. i had to get someone to hold the pully wheel for me so i could unbolt it. should have loosen it off 1st before i took the belt off.
i made a mistake by not puting any sealent stuff on the gaskets before i insalled it. its still like that and so far it seems to be holding up pretty good.
the gasket just came off with the pump. i barly had to do any scraping.mostly just whiping it clean really. wasnt overly hard.
but i think its just the belt that needs to come off. and pretty much about it...
eightsixseven
Dec 16, 2024 01:50 PM
NBrehm
Aug 25, 2015 11:49 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
