location of coil mounting bracket?
Old Jun 10, 2001 | 02:54 PM
camaroguy99's Avatar
I'm installing a TPI setup that is replacing my TBI system. I have that angled bracket that mounts the coil and that vacum solinoid but can't seem to find out where it mounts to. Any help would be great thanks.
Old Jun 10, 2001 | 09:20 PM
irocrob's Avatar
Car: 1985 Chevrolet Camaro IROC
Should attach right nect to the distributor on the passenger side of the intake (last one or two intake bolts). I just took a TPI off an 87, pretty sure that is the location. I have an integral coil on my 85.
Rob Kowalski
85 IROC, 305 TPI, JET AFPR - 45 PSI, B&M Megashifter, B&M Shift Kit, 3.42 gears, SLP Airfoil, SLP 1 5/8 headers and cat back system, gutted cat, gutted airbox, MAF screens removed, K&N, more to come!!
Old Jun 10, 2001 | 10:46 PM
thats what I thought but it doesn't allow the bolts to screw all the way down. should I use spacers or are there supose to be studs for those last 2 holes?
Old Jun 11, 2001 | 12:01 AM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
if I remember right it was just two regular intake bolts. you don't have an aftermarket base do you? on the edelbrock & accel bases I've installed I had to grind out a notch on the coil bracked to clear the intake port.
Dan
87 IROC-Z, 5.7,auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, Accel .219 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon- DFI or prom burner, Dart Iron Eagle 200cc heads, 6" rod 383 or a 406
1987 Camaro Z28 - 5.2tpi, auto, 3.73s, ram air, airfoil, ported plenum, !cat, !tbcoolant, !smog, !4th gear
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N - SOLD
Old Jun 11, 2001 | 12:54 AM
It's a TPIS big mouth. I can't believe they wouldn't tell you that in the instructions.
Terrell351
Jun 13, 2021 01:13 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Genopsyde
Nov 11, 2015 10:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
