13's?????
Old Jun 9, 2001 | 11:35 PM
afireinsideGTA's Avatar
13's?????
I just recently bought a 1990 GTA WS6 (350). I had some money left over and am buying a few things for it. I was wondering if anybody knew if these mods could possibly put me in the 13' in the 1/4. im new to this TPI stuff. Hooker Cat back, subframe connecters, underdrive pullys, strut tower brace, airfoil, 52mm throttle body, 160 theremostat, b@m shift kit, and soon 3.73 gears and SLP cold air.
Old Jun 10, 2001 | 12:45 AM
rondubbs's Avatar
a few words of advice before you throw money away:
dont buy a larger tb,, the stock one is good enough to feed like 400hp. get the airfoil.
get a 170* or 180* stat and a fan switch so your fans come on earlier to cool off the car.
B&M shift kits are no good, if you want a shift kit get a transgo,, or even better (and cheaper)just get a vette servo and .500 boost valve for firmer shifts.
the hell with slp, make your own cold air induction kit and save 150$. look at the tech articles for some ideas. get a k&n filter too
PS welcome aboard and you have no chance in hell of hitting 13s
Old Jun 10, 2001 | 01:04 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
<font face="Verdana, Arial" size="2">Originally posted by ron rizzotti:
</font>
What's wrong with B&M shift kits? i have the stage 2 kit in for over 60K miles with no problems...and no way in hell for 13's??
These are my mods:SLP catback flowtech headers the shift kit mentioned above air foil gutted MAF stage 2 fastchip homemade ram air panhard rod and koni adjustables all around and SSM SFC's
Car was ran on drag radials ran a 13.89@99 his mods aren't too far from mine plus he's speed density which is good for a few more horses...my valves covers have never been lifted...not bad for just a few bolt ons...
Originating member of the SJNEP Crew
Member of the Jersey Fbody Crew(JFA)
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM RiceEatinGTA***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
[This message has been edited by fly89gta (edited June 09, 2001).]
Old Jun 10, 2001 | 03:26 AM
Z_Ghost's Avatar
92 Z 350, auto, 3.23 posi, 133,000 miles
Hotchkis suspension
Nitto drag radials
air foil
msd 6al, blaster coil
60' 2.001
1/8 8.839
1/4 13.851
mph 98.16
Old Jun 10, 2001 | 10:49 AM
rondubbs's Avatar
the only way to tell for sure is to go to the track,, i guess i might of been venting from my miserable runs,
but im still saying you wont hit 13s.
just go to the tranny board and ask around about B&M kits, if you dont believe me
Old Jun 10, 2001 | 11:16 AM
Well, ill be going to the track sometime in the next month. Soo... i guess ill find out fer shure there.
Old Jun 10, 2001 | 01:42 PM
fly89gta's Avatar
Car: 2018 Camaro SS
</font>
how can u say he won't hit 13's? there were 2 examples posted...not a lot of mods...and boom 13's. It depends A LOT on the driver...u can have really fast car but if the driver can't drive it well..then its not going anywhere..
Also have u had experience with B&M shiftkits or are u just listening to what other people say? You are right though...the Transgo is a better product
Old Jun 10, 2001 | 10:16 PM
mirage2991's Avatar
3.73's are too much gear for a stock TPI. I'd stay with either 3.23's or 3.42 if I were you.
I don't belive in the airfoil either nor do I about underdrive pulleys. but that's my 2 cents....
Old Jun 10, 2001 | 10:38 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I dont know how the hell you guys get in the 13's with 2 mods .i cant even get 14.1 with a new base and as&m runners , headers, catback , shift kit and other $hit on my 89 350.
Old Jun 11, 2001 | 12:18 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
corrected for altitude anyone?????????
1987 GTA L98 MD8 GH3
355 '97 Vortec 4-bolt block, TRW(suck) forged pistons 10:1 CR, TFS 23*, LT4 Hot Cam, Ported plenum and intake, SLP Siam Runners, Edelbrock TES, gutted Cat, Flowmaster, Home-made cold air system w/ K+N cone and AFPR, TB bypass, AirFoil, !AIR, !A/C, !EVAP, 2300 stall.
"Stop Lights timed for 35Mph are also timed for 140Mph"
Old Jun 11, 2001 | 01:18 AM
Z_Ghost's Avatar
I did that run in February with the air temp around 45* and no humidity. I ported the plenum, relocated the air temp sensor and with the temp around 80 and a lot of humidity and have run 13.89 as my best.
I think I am around 600' above sea level.
The 3.23 seem to work out really good for my car.
