First time at track
Old Jun 10, 2001 | 07:13 AM
Ron Mullins's Avatar
First time at track
Best of 3 runs was,
R/T .858
60' 2.265
330 6.504
1/8 9.967
mph 71.74
1000 12.907
1/4 15.424
mph 89.13
I know, it sucks. I got better everytime as far as reaction time, speed and time was about the same on all 3 runs. So what should I do to the engine next?
91 Formula WS6
Home Made Ram Air,K&N Air Filter,Air Foil,
Ported Plenum,Underdrive Crank Pulley, Crane AFPR, Edelbrock High Flow TPI Runers, Holley 19lb Fuel Injectors, MSD6AL, SLP Headers, SLP Y Pipe & Complete SLP 3" Exhaust and Muffler, High Flow Cat, Mobil 1 Oil, Hotchkis STB, Spohn LCA's and Panhard Bar and other polyurethane goodies.
Http://www.geocities.com/91formula
Add your 91 F-Body to my 91 F-body's Links page, or be added to my F-Body Links Page.
Old Jun 10, 2001 | 05:10 PM
MrJ's Avatar
MrJ
It does suck... you are missing about 6MPH and close to a second off of your ET and trap speed.
Sounds like you have some major tuning to do.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
ported TPI setup
Built on Wednesday
Old Jun 10, 2001 | 05:18 PM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
Yeah man, 15.6 is stock, and all that stuff HAS to be worth more than 2 tenths I raced mine for the first time friday and got 15.4 w/ a cold air kit, so you're prolly being robbed of some power. best of luck finding the problem
http://www.tcnj.edu/~esposit3
  • '89 Trans AM, 305 TPI, 5-spd
  • '86 Firebird, 2.8, Auto
AOL IM Name: JimmyTime5
Old Jun 11, 2001 | 12:20 AM
MrJ's Avatar
MrJ
Just to put things into perspective, my T/A ran 14.97@93.27 (on a 2.33 60 foot) with the mods in my sig, minus the ported TPI, shiftkit, and converter. Basically just a catback and a high flow cat. You should be a good 3mph faster than that.
You should probably think about getting into PROM burning, an optimized PROM would probably help you out a lot. Also since you have an AFPR, you could try experimenting with different fuel pressure settings at the track next time you go, maybe you are running lean up top, that would give you the low trap speed that you are running.
Old Jun 11, 2001 | 03:28 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Seeing as how you have speed density, a custom eprom would definitly help. BUT...you have another problem somewhere else, you just need to find it... When was the last time you checked the cap, rotor, plugs, plug wires, etc? might be something to look into even if it was just two - three months ago...
Any kind of traction problems?
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
Old Jun 11, 2001 | 05:58 PM
I didn't have any trction problems that I could tell. The cap and rotor were replaced a few months ago, Auto Zone stuff. The plugs are a good 4-5 years old and wires also. Wires are Accell 8.8mm wires. I was thinking about an Ed Wright chip, but I was going to install 1.6 RR first, then get the chip from Ed. Talking to other people they suggested gears or a miniram intake. Don't have the money for the intake, so maybe some gears first. I did dyno the car a couple weeks ago and got 208 rwhp. We adjusted the the fuel pressure up 2 pounds and lost 1 hp. Any suggestions what to do next is greatly appriciated.
91 Formula WS6
Ported Plenum,Underdrive Crank Pulley, Crane AFPR, Edelbrock High Flow TPI Runers, Holley 19lb Fuel Injectors, MSD6AL, SLP Headers, SLP Y Pipe & Complete SLP 3" Exhaust and Muffler, High Flow Cat, Mobil 1 Oil, Hotchkis STB, Spohn LCA's and Panhard Bar and other polyurethane goodies, Dynoed 208 rwhp, best 1/4 15.4 @ 89 mph
Old Jun 11, 2001 | 07:01 PM
transam350's Avatar
I got a 15.21 with my GTA which has a caprice replacement motor and only dynoed at 173 rwhp. sorry man but something isn't right.
89 T/A GTA 350 TPI free mods and all stock
15.21 @ 89.7
Street Lethal
Apr 30, 2019 12:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
