My Formula 305 TPI spits black
Old Jan 5, 2008 | 04:49 PM
Blocker's Avatar
My 1989 Formula Convertible is sick. The car has a 305 TPI, a 5-speed and dual cats. It starts fine, but usually idles a bit rough. It also feels a weak, has a stumble at steady throttle and spits black soot out of its tailpipe. The car is essentially stock and has 62,000 miles on it. It obviously sits more than I drive it. Have my injectors gotten old? Any help would be greatly appreciated.
Old Jan 5, 2008 | 07:36 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Re: My Formula 305 TPI spits black
I have the same problem with new injectors, its not always the case but is alot of the time.
Old Jan 5, 2008 | 08:28 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
The soot coming out of your tailpipe is probly just carbon in the exhaust and it's getting carried out by the moisture in the pipes, take the car out, and really drive the thing, run it hard, put some good high octane gas in and drive it. You could probly change your air filter and put in a good o2 sensor, and hell do a full tune up, But mainly just go drive it.
Old Jan 6, 2008 | 10:11 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Sounds like yer running rich. Mine did everything you stated until I leaned out the programming.
Old Jan 8, 2008 | 10:39 PM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
my car is doing exactly the same thing and im getting sick of it...im also getting a rich code from my o2 sensor. when you rev your car to about 2000 in park does it feel like you will vibrate out of your seat? haha
i need to check the injectors im pretty sure...ohm them out
Old Jan 9, 2008 | 06:17 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Vibrating that bad? You may want to make sure everything's firing. You might have a dead miss.
Old Jan 9, 2008 | 08:09 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Run some Sea-foam through it.
And beat the crap out of it for a 1/2 a tank of gas.
I remember carbed cars....I used to pour water down the carb and rev it up to keep the car running. It was the easiest way to clean carbon build up.
Old Jan 12, 2008 | 06:49 PM
jerflash's Avatar
well looks like i may have found the problem
6 out of 8 injectors are bad...ranging anywhere from 2 at 16.7, 2 at 14 ohms, 2 at 10 ohms, and 2 at 7 ohms...16.7 is what they are supposed to be around
a buddy of mine has a set of 19lb for injectors off his mustang that is is going to give me for free...they ran fine on the car he had but i will ohm them out first
Old Jan 13, 2008 | 12:18 AM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
post some pics!! Thats a very rare car!
What colour??
jaridjohn
Jul 8, 2024 03:49 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
