58mm Holley A ir Throttle ?
Old Jun 22, 2001 | 03:42 PM
MR. KIDD's Avatar
Car: 85 IROC
Engine: 406
Transmission: A4
Anyone using a holley air throttle having any problems with them beside the price getting ready to purchsae one. THANKS FOR ALL OR ANY REPLYS.
Old Jun 22, 2001 | 04:59 PM
b92z28's Avatar
the auto zone near my house has the holley throttle body for 232$
92 z28 170,000 miles 14.20 on goodyear eagles before exhaust only mods k&n and slp 13/4 headers and dual 2 1/2 exhaust
87 trans am 12.20 on motor too many mods to list
Old Jun 23, 2001 | 02:38 AM
86_Dan_Z28's Avatar
Car: 86 Z28
It is not an air throttle, it is a throttle body.
Old Jun 23, 2001 | 12:02 PM
camaro6spd's Avatar
yes please it is called an Throttle Body, not an AIr throttle, no offence
Old Jun 23, 2001 | 02:15 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
OK, now that we know what to call it...
The throttle position sensor (TPS) bolts in my stock throttle body were metric. For some reason Holley thought it would be nice to tap theirs with a standard SAE bolt/thread size so that I would have to find new TPS bolts instead of re-using my nice stock ones.
Speaking of the TPS, the relief cut into the throttle body for the TPS wiper to swing was not cut deep enough on my Holley TB. I had to file the wiper arm on the TPS sensor to clear the throttle body otherwise it would stick.
You must take the small coolant passage & idle air control (IAC) manifold off of the bottom of your stock throttle body and install it on your new one. Chances are, the stock gasket that has been on there for the life of the car will tear and will not be re-usable. Buy one of those before you get started. I don't know Why the manufacturers of aftermaket throttlebodies don't include this gasket. It would cost them pennies and improves the value perception greatly when you don't have to dig up small things like that.
Other than that it is a good piece.
It includes the throttle body to plenum gasket. (But where is that IAC manifold gasket at Holley??)
It also includes 4 new allen head mounting bolts to attach it to the plenum. (But what is the deal with tapping the TPS bosses with a different size than stock and not including the two now required new size bolts Holley??)
The finish is good (looks better than any other as far as I am concerned).
Other than the TPS wiper interference the fit is good.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
Old Jun 23, 2001 | 05:36 PM
MR. KIDD's Avatar
Car: 85 IROC
Engine: 406
Transmission: A4
Thanks guys for the correction and thank you very much for the information on holley THROTTLE BODIES (IROCKz4me).One other ? any of you using edelbrock throttle bodies any problems. THANKS FOR ALL REPLYS. :COOL
Old Jun 25, 2001 | 12:39 AM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
I didn't have any problems using the stock tps bolts on mine, but I know what you mean about the tps arm. I just used a washer between the tps and the tb on mine but I will probably trim the arm a little before the 406 goes in.
The holley is a much better design than the edelbrock/bbk. Just look at the space in between the bores. The holley has a cast-in airfoil where the edel. is just flat. Also I've heard about some people having porosity problems w/ their edel/bbk TBs.
Dan
87 IROC-Z, 5.7,auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, Accel .219 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon- DFI, Dart Iron Eagle 200cc heads, 406" money pit
1987 Camaro Z28 - 5.2tpi, auto, 3.73s, ram air, airfoil, ported plenum, !cat, !tbcoolant, !smog, !4th gear
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N - SOLD
Old Jun 25, 2001 | 09:45 AM
GhoSSt's Avatar
You can get a whole new TB gasket pack, including the IAC housing gasket, TB to plenum gasket and upper plate gasket for 5.00 from Autozone, its a GP Sorenson P/N 96-3008.
Kelly 'GhoSSt' Rosato
Old Jun 26, 2001 | 01:24 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
How do y'all feel about the BBK Throttle body, I have heard that it somtimes can whistle. Other than that... any comments?
John
87 Formula Yellow/Black
Engine & Transmission
.040 over 5.0 converted to TPI, 9.5:1 Compression, SLP Cam Dur 206/212, Lift 480/487, Cent Line 112, SLP headers, SLP cat-back exhaust, K&N Airfilter, Modified Stock cold air intake, Ported & polished Stock TPI intake, Holley Adjustable Fuel Press regulator, AC Rapidfire Spark Plugs.
Gil Younger (no yo-yo) Shift Kit, Aluminum Driveshaft, 3.73 Posi gear
Suspension & Brakes:
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Hotchkis strut tower brace, South side machine frame connectors, Custom reinforced control arms and pan hard bar.
Interior:
Custom Leather interior, CUSTOM Yellow Gauge Faces, Kenwood Receiver, Pioneer Speakers, Kicker Substations, Kenwood 10 Disk Changer, Pioneer Amp.
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Old Jun 26, 2001 | 06:04 PM
sparks383iroc's Avatar
Car: Mullitt mobile :)
Engine: it's stock LOL
Transmission: 700rJunk
Axle/Gears: 2 much 4 street not enough for strip
I have the Edelbrock/BBK TB. Had no problems with any bolts (bracket or otherwise). It does whistle at idle and low RPMs (don't know about higher RPMs, can't hear it over the exhaust).
Sparks a flyin'
F.I. 57 Belair
Aug 23, 2021 01:09 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Magman
Sep 14, 2015 01:30 AM
Randomtask2
Sep 7, 2015 05:06 PM
